Tire recommendations for 19" rim
Hello,
I know this topic has been beaten to death and I am in the same predicament as all others who used the PS2 235/35 - 315//25. My vehicle is a 2003 911 turbo. No suspension mods. Currently running 8.5/53 and 11.5/44 19" rims with PS2 235/35 and 315/25.
Put these on the car when I bought it new in 03. 18k miles and 13 years later and its time for new shoes. I understand the possibilities of the viscous coupler situation as it relates to the front dif. I understand that the current set up is ideal and no longer available (PS2 or PSS) but I would really like to stick with Michelins as I run them on all my vehicles when possible.
Can anyone give me any alternative tire sizes that will work.
I have read that some guys have switched to a 245/35 and 305/30.
Does any one out there have any long term experience with this size as it relates to the AWD 911s differential threat ?
Also, will the 245/35 - 305/30 fit with no rubbing. The 235/35 - 315/25 set up is extremely close.
Any help would be appreciated
I run
19x9 +50
19x11.5 +38
245/35 - 19
305/30 -19
Bridgestone s04
Coilovers at Gt2 height
Alignment nearer gt2 levels of camber than normal turbo. No rubbing issues. Traction is way better than on my 18" stock setup running hankook v12 (came with car). With the 18" I can spin all 4 with hard acceleration in low gears. I have 6000miles with the 19s and my vicious coupling is still working.
19x9 +50
19x11.5 +38
245/35 - 19
305/30 -19
Bridgestone s04
Its a shame that Mich stopped producing a 315. I would have loved to try them in a PSS. I wouldn't mind a slightly taller side wall like the 305 in a PSS as it may help the harsh ride of a 19" (then the wife might enjoy riding in the car) A little worried about the 295 on an 11.5 as it my not look correct. Almost looking stretched. Very close in width. Just worried about inner rubbing with the 245 - 305 set up. Dont get me wrong.. also worried about front diff.
Thats a nice looking fitment. Looks good at the rim and wheel well. You are running 38 offset and lower than stock ! Im running a 44. How is the clearance on the inner well ? My 44 puts me closer to the inside than your 38. My 315 barely fits a finger at inner lining.
Re-11 is a fantastic tire. Imo the best all around street tire if you are not as worried about wear. The pss last longer but don't have the dry grip the re-11 does.
Re-11 is fantastic in the rain as well and many track guys when them for track tires on rainy days when taking off slicks or semi slicks.
If highly recommend them. Those or the re-71r which is actually slicker than the re-11 but not as good in the rain and wear even faster. Also let sizes available but they are available in 245/305 on 19s
That's the biggest you can fit really. I'll have drag radials though for track time and some 18s with 275/335 combo for circuit use
I'm running 245/295 Michelin PSS combo on my car. That's the closest I could get diameter wise front to rear. I could step up to 255 front and run 305 rear, but those damn 305s are hard to find!
