Stiffer Wastegate Springs?
Old 01-23-2006 | 12:59 PM
Kevins wastegates really rock....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #32
Old 01-23-2006 | 02:11 PM
K24madness's Avatar
K24madness is infamous around these parts
Originally Posted by Kevin
Gunter you can PM me, I have them in stock..
The Tail springs aren't a bolt in. They aren't designed for the KKK accuators. You have so much coil bind with there springs it just isn't correct.
Odd statement considering my positive results and the fact that Tial does work for EVO on the various Garrett turbos. They also manufacture some of the best wastegates around.
FWIW they were an easy bolt in for me. Maybe you are confused with another "tail" company.
Look at how flat the boost log is when using these springs. This is from my 993tt with K24 hybrids (not Kevins) and greddy EBC
File Type: pdf
  #33
Old 01-23-2006 | 03:10 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
WOW, cool plot - I love that sort of detail!
Question:
1 How did you get that plot?
2 Why does the MAF voltage max out even as you keep accelerating and using more air? If the MAF is undersized, you must revert to the stored ECU values for timing and injector pulse width based on RPM and Load correct? Would it not be better to get a larger MAF that reads your airflow accurately up to the max, for more adjustability? Perhaps WOT doesn't require a lot of 'tweeking' to get maximum safe power?
  #34
Old 01-23-2006 | 04:00 PM
K24madness's Avatar
Tial isn't making a wastegate for the K16 or K24.. You have to purchase one of there springs frrom there list of application for there own wastegates. Tial does make good wastegates such as the one on my 930 and 965.. It makes more sense to purchase a kit made for the KKK actuators.
Greg the owner of TIAL made this kit for the KKK turbos. It includes billet clamps and special springs. He would not sell something that does not work. I use them with very positive results.
  #35
Old 01-23-2006 | 04:10 PM
K24madness's Avatar
They were made for the Garrett cartridge conversions that were installed in KKK housings. Similar to the Evo conversions.
No they have a different accuator assembly they use with the garrett cartridge kit. Its not a modified KKK one.
  #36
Old 01-23-2006 | 04:26 PM
K24madness's Avatar
Thats pretty funny. I should have seen that one coming.
  #37
Old 01-23-2006 | 06:42 PM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
I'd like to get info on a group buy!
  #38
Old 01-23-2006 | 06:54 PM
I have both.. a tial 44 mm on gt 35r garrett ball bearing turbo( evo8).. as well as Kevins billet wastegate on my stage 5 zero clearance(TT)... both are great and do the job. Huge difference in spool up and sustained boost.. doesnt drop off like the stock wastegate under full load.
9.66
click to view
  #39
Old 01-23-2006 | 07:53 PM
K24madness's Avatar
Mark,
What are you replacing your stage 5 turbos with? With all of the success of the garretts I have to guess thats your plan. If so you will not be disapointed.
Tom
  #40
Old 01-23-2006 | 08:07 PM
Yes Im going to a set of gt35rs and 44 mm wastegates with .8 bar springs.... all custom piping I/cs.... headers, exhaust.. etc.. and much more....
I must really say that Kevins stage 5 zero clearance turbos are the ****....I had k24s race FVD turbos and they were a dog.... too much lag... i didnt hit full boost til top of the 3rd or 4rth gear... stage 5s are awesome... simply no lag... seriously.... it was the best set up I had without having to get into the engine and or add injectors/fuel pumps.
9.66
click to view
  #41
Old 01-23-2006 | 08:16 PM
K24madness's Avatar
Sounds like you have a monster plannned. I have seen SCARGO install many such setups. You will not be disappointed!!! Sounds like you are doing the external wastegates. Very good move. I have only seen one set of custom IC's for the 996. It is on Chads car. I must say they are impressive. This is an area often overlooked. When will it be done? Which injectors are you going to use? I can recommend some.
Those FVD turbos sound pretty sad. Here is a 1-3 gear log of my home brew K24 hybrids. I hit full boost in first gear with my 993tt.
File Type: pdf
  #42
Old 01-23-2006 | 08:49 PM
iLLM3's Avatar
Wow so much information, must do more research haha!
  #43
Old 01-23-2006 | 09:13 PM
thas exactly how Kevins stage 5 act... full boost 1st gear... i freaked out...
and the stiffer spring turns this into a whole different car.
9.66
click to view
  #44
Old 01-23-2006 | 09:18 PM
here is a pic of my new I/Cs
9.66
click to view
  #45
Old 01-23-2006 | 09:21 PM
iLLM3's Avatar
Wow Mark nice!! Damm i want Kevin's turbos badly, Mark lemme know
