Fabspeed Super Sport exhaust question.
Originally posted by sharkster
That's the same one I have, it is a real Fabspeed Super Sport exhaust, which seemingly was the most popular one at the event
So label on the exhaust said "GT2 Twin Turbo" is that a older version or they simply have only one version. Cause Fabspeed site show 996TT on the Label.
Originally posted by toffeGT2
That was quick! thanks sharkster.
Laguna Seca will kick out most cars that have over 91 decibels. Even with my old FVD Exhaust I got flagged. With Fabspeed it would be even worse. You can still race but you have to let off the throttle from turn 5 to 6. That is where the sound booth is.
That is the only thing that stinks about Laguna (sound restriction)
Originally posted by oruehr
A TT at Laguna Seca last weekend was using the Fabspeed exhaust and got kicked off because it was just too loud.
Has this happened to anyone at other track events?
As for track sound limits, it'll depend on the distance from the meter, the max db level allowed, and a few other factors. Laguna Seca obviously has one of the lowest allowed limits.
I used to run the sound meter for SCCA autocrosses in San Diego. Learned a few tricks for fooling the meter. The best approach is to just aim your exhaust tips away from the meter, or down toward the ground. Since the 996TT exhaust tips can be easily removed/attached, I'd fabricate a set of tips that can be pointed either down at the ground, or away from the meter. That should buy the driver a lot of room to work with...
joseph_number1
07-19-2018 05:45 PM
oddjob142
08-19-2015 12:27 PM
