Seized Engine
Seized Engine
OK, this is for a friends car, not mine.
Driving along in 3rd gear at about 2600 rpm, the engine made some knocking sounds, the CEL started Flashing and the car lost all power to the point where it stalled and wouldn't fire up again.
Had the car towed to a local dealer and the dealer stated that the engine has seized due to running too lean on cylinder number 3.
He has just got extended warranty on the car as it is a 2004 model and just ran out of the original warranty, he has several mods including Intake, Fabspeed Exhaust and ECU Upgrade for K16 Turbos.
We haven't got any more info from the dealer yet as to whether or not they would cover this, can the dealer deny warranty based on the mods alone, is this something that happens to these motors, has anyone heard of this happening in the past, the car has about 12,000 miles on it.
Any input or advice would be appreciated.
Originally Posted by shiggins
If the upgraded ECU altered the fuel maps, they could easily deny coverage. Though, they have to prove that the mod was responsible for the siezure.
Ive seen 2 blown engines on a chipped TT over the last two years.... not going to mention which company casue I dont think it was their fault. it was a 2004 tt with 800 miles... I saw the PS2 readout at the dealer.. they r my friends.. and it had 60000 hours overrevs....(they calculate it in hours for soem reason)...
its because the diver probably downshifted into second instead of going into 4rht...
2001 996TT 3.6L and stock ECU
Originally Posted by ari
60,000 hours of over revs?
I physically saw the ecu pulled out with a sticker (tuner) on it...
I don't see how the ECU could cause it to be lean on 1 cylinder. Doesn't an over lean turbo motor burn the pistons and smoke a lot before it fails? This sounds like a valve train problem.
If something like that goes down, I'd attempt to return the car to stock, reflash and all, prior to taking it to the dealer(new TT motor is 44k). The way in which the car was modified gives them a wide window to deny the claim.
