Budget Turbo to GT2 Front Bumper Upgrade
Old 11-26-2019 | 11:57 AM
Jay.'s Avatar
Jay. is infamous around these parts
Looking to start upgrading my 996T with a simple front bumper upgrade. I've read a bunch of forum posts and have a bunch of conflicting answers, so I figure I'll try and ask questions as simply as possible.
I've been using this as my main source of information:
https://www.6speedonline.com/forums/...n-996tt-4.html
That's for a functional conversion, I'm looking to do a "budget" conversion, which will look aesthetically correct as cheaply as possible.
Am I correct in thinking all I need is:
Front Bumper Cover
Center Top Grille
(6) Allen Screw (secures grille)
(6) Hexagon Nut (secures grille)
I have a FRP front bumper already, which has the front lip and air inlet trims already fixed to the cover. I was hoping I could get away with buying the center top grille and fettle my existing turbo parts instead.
Is the wheel arch liner required? If not, this will save me approx. $300
Are the headlight trim brackets required? If not, this will save me approx. $300
If so, are the gakets required?
Old 11-27-2019 | 03:48 PM
s65e90's Avatar
s65e90 is infamous around these parts
No need for the liners or the headlight trim. You need the bumper extension for tow hook, and center vent grille. Later on you cant cant the front rad and add the chimney stack behind it.
Old 11-27-2019 | 03:50 PM
Jay.'s Avatar
The chimney isn't required right? I believe I can just space out my existing tow hook?
Has anyone documented something similar to this?
Thanks for the reply
Old 11-27-2019 | 06:27 PM
s65e90's Avatar
Correct. You don't really need anything other than the front bumper cover and center vent. Most are probably just like that done for looks.
Old 12-01-2019 | 08:00 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Mike Kelley did a real nice write on adding a GT2 bumper on a Turbo. It should provide you some ideas and lots of pictures.
Old 12-04-2019 | 02:02 AM
Jay.'s Avatar
I can't find this, is it on here?
Old 12-05-2019 | 04:40 AM
Gunther's Avatar
Here is the link: https://www.6speedonline.com/forums/...rsion-diy.html
I hope this helps you on your project. It has a comprehensive list of all the parts.
Steve Jarvis
03-29-2015 01:15 PM
superchicken
10-12-2012 04:37 AM
JoelPirela
02-06-2008 08:33 AM
Quick Reply: Budget Turbo to GT2 Front Bumper Upgrade
