Anyone have an accurate Syvecs 996tt S7+ pnp pinout diagram??
The diagram on their website lists a three plug set up and doesn’t depict the actual factory replica style plug-ins for the S7+ plug in place set up for the 996 turbo.
Has anyone received a copy of a pin out that shows how the Syvecs has each plug pinout laid out?
Which ecu did you get? With the s7 you can get a standard ecu with harness that connects to the Porsche or a true plug and play version that has the 996/997 and an addition plug for extra sensors.
hard to help without know which version you have.
It’s the true plug and play version with no adapter harness, the stock plugs plug directly into the ECU.
it did not come with a wiring pin out diagram or anything, except for the extra plug for the accessories.
No problem.
here is the link - http://www.syvecs.com/downloads/Syvecs_S911_Manual.pdf
this has both wiring pin outs. Go right to the bottom and you will see the aux pins outs for your version.
