Gt700 kit
Originally Posted by jags911tt
...Zippy - what do you think of your gt700?
Thanks, bur can you be alittle more specific as to driving experience. Also did you go from a gt640 to 700? If so, what were the main differences between the kits
much appreciated
Jags
much appreciated
Jags
Driving experience - not a ton of difference from the 640. The upgraded fuel rails, injectors and pump seemed to make a lot of sense to me. I was always a little concerned the stock fuel system was over-burdened by the significant air flow increase produced by the Garett modified KKKs. As Stephen mentioned, the increased capacity of the upgraded fuel systems opend the door for future power increases. This could mean GT800 turbos, increased airflow via head work, cams and/or intercoolers or some combination of the above.
Also - other than different software, enigine rebuild, and turbos, is there anything else added to the gt750 and 800 from the gt700?
2001 996TT 3.6L and stock ECU
Originally Posted by Craig
Craig
I'm so glad you are on this forum. Your pure enthusiasm for the pursuit of horsepower and speed is a true inspiration to me. Keep up the good work my friend!
tw
Originally Posted by Zippy
Markski - Are the GT640/700 turbos = to GT30R Garrets?
ist only when u go with the gt700/750 is when u have that option....
the gt640 uses a 5 bar fuel pressure regulator..... the gt700 and up uses the hole new fule system....so its set up for bugger turbos..... these are stuffed into the kkk housing... u have a gt700 dont u ?
Yes I do - but it's my understanding that the turbos on the 640 and 700 are the same. 750 & 800 are a bigger set. Hence my question regarding your previous statement - "like if u have the gt30r garrets then u can us ethem with the gt800.. tahst what sharky has and even Craig... quicker spool..." I assumed you were implying the 640/700 garret mod turbos were gt30r's and you could optionally use these as opposed to moving up to the bigger turbos that are a part of the 750/800 kit?????
it doesnt even make sense cause the gt640 uses a 5 bar FPR.... good for about 600 or HP.... anything after that u have to go with a fuel system...
I just personally dont see how they would be sticking gt30s on a gt640.
I think that comes with a gt25r garrett inside a kkk.
