Gt700 kit
#32
maybe ur right....
2001 996TT 3.6L and stock ECU
#33
#34
Originally Posted by jags911tt
Thanks gang. What does the Larger TB and modified ypipe do if anything?
Craig
#35
Also - other than different software, enigine rebuild, and turbos, is there anything else added to the gt750 and 800 from the gt700?
Craig
#37
Originally Posted by willcoxmd
craig,
I'm so glad you are on this forum. Your pure enthusiasm for the pursuit of horsepower and speed is a true inspiration to me. Keep up the good work my friend!
tw
tw
Craig
#38
Originally Posted by Zippy
Must be gt25r on the 640 & 700 then. I'm using the same turbos as on my 640 kit. Upgraded fueling, intake and ECU to get to 700.
Craig
#39
Chad: The 640/700 turbos look like they could be a GT2871R - 472560 - 15 or perhaps a GT2871R - 743347- 1 based unit. Both indicate a twin turbo application up to 720 HP. The GT30 series indicate twin turbo application up to 950hp. Im assuming this means the GT30 turbos would be used for the GT750 - GT900 EVOMS packages. For your application Chad, it appears that a GT37 or GT40 makes the most sense?
#40
Originally Posted by Craig
I *thought* the 640/700 package used a kkk based turbo, but Im not sure.
Craig
Craig
#41
they are kkk based since ur headers fit directly and the exhaust....
#43
i think they use something like a k27 housing....
