Cobb gauges list
Cobb gauges list
Doesnt seems anything below can read as boost gauge? MAP? Thanks
And what monitors do you guys have set up on the gauges page?
Useful Monitors In Every Situation:
- Ambient Pressure
- Barometric pressure reading, allows a tuner to see the atmospheric pressure where you drive your car and makes it easier to compensate for altitude.
- Boost Error
- The difference between the amount of boost requested by the computer, and what the vehicle actually has.
- Engine Oil Temperature
- Temperature of the engine oil helps with checking health of the engine, how hard it's being pushed, and whether the oil would need a cooler or to be changed.
- Engine RPM
- Engine speed in RPM (revolutions per minute) Provides a refereance of what the engine is doing so that all the other values make sense.
- Engine Temperature
- Temperature of the engine allows us to see if the vehicle is having problems related to overheating, or being pushed too hard.
- Ignition Angle (Actual)
- Final ignition timing value after all corrections.
- Injection Time
- Injector open time in milliseconds.
- Intake
- Air Temperature-Intake air temperature in the intake manifold.
- Knock Sums Cyl. 1
- Knock Sums for cylinder number 1
- Knock Sums Cyl. 2
- Knock Sums for cylinder number 2
- Knock Sums Cyl. 3
- Knock Sums for cylinder number 3
- Knock Sums Cyl. 4
- Knock Sums for cylinder number 4
- Knock Sums Cyl. 5
- Knock Sums for cylinder number 5
- Knock Sums Cyl. 6
- Knock Sums for cylinder number 6
- Lambda Bank 1
- Air fuel reading from the wideband sensors Bank 1
- Lambda Bank 2
- Air fuel reading from the wideband sensors Bank 2
- Long Term Fuel Trim Bank 1
- Long term changes made to the fuel table for bank 1 of the engine.
- Long Term Fuel Trim Bank 2
- Long term changes made to the fuel table for bank 2 of the engine.
- MAF 2
- Mass air flow reading Bank 2
- MAF
- Mass Airflow Reading Bank 1.
- Manifold Absolute Pressure
- Intake manifold pressure
- MAP
- This is also considered to be boost pressure.
- Pre Throttle Pressure Sensor
- Pressure in the intake system before the throttle body (997.1 only)
- Short Term Fuel Trim Bank 1
- Short term changes made to the fuel table for bank 1 of the engine.
- Short Term Fuel Trim Bank 2
- Short term changes made to the fuel table for bank 2 of the engine.
- Throttle Angle
- Angle of the Throttle
- Vehicle Speed
- Vehicle Speed
List of Available Monitors:
- Actual Camshaft Angle Bank 1
- Actual camshaft angle for Bank 1.
- Actual Camshaft Angle Bank 2
- Actual camshaft angle for Bank 2.
- Actual Gear
- Current transmission position.
- Battery Voltage
- Battery Voltage
- Catalytic Converter Temperature (Modeled)
- Temperature of catalytic converter. This is a modeled temperature so not 100% accurate.
- Cold Start Enrichment Range 0
- Cold Start Enrichment Range 1
- Cold Start Enrichment Range 2
- Coordinated Torque for Cylinder Filling.
- Current Starting Adaptation Factor
- Amount of correction in percentage of correction when starting the car.
- Distance Since Power Failure
- Distance amount since a power failure.
- Distance With Check Engine On
- Distance with a check engine light on.
- EGT Downstream of Cat (Modeled)
- Exhaust gas temperature behind the catalytic converter. This is a modeled temperature so not 100% accurate.
- EGT Upstream of Cat (Modeled)
- Exhaust gas temperature before the catalytic converter. This is a modeled temperature so not 100% accurate.
- Engine Compartment Temperature
- Engine compartment temperature. Measured in the back of the car.
- Engine Torque Loss
- Fuel Level.
- Maximum Torque
- Maximum torque value
- Minimum Torque
- Minimum Torque Value
- Nominal Throttle Plate Angle
- Actual Throttle Angle
- Operating Time Since Power Failure
- Amount of time since power failure.
- Radiator Fan Request Value
- Radiator fan on and off request.
- Relative Secondary Air Mass Bank 1
- Relative Secondary Air Mass Bank 2
- Set Point Torque
- Set point torque value.
- Turbo Duty Cycle Bank 1 (Target)
- WGDC/VTG target duty cycle from 0-100%
- Turbo Duty Cycle Bank 2 (Target)
- Turbo Duty Cycle Bank 1 (Actual)
- WGDC/VTG actual duty cycle from 0-100%
- Turbo Duty Cycle Bank 2 (Actual)
- Target Camshaft Angle Bank 1
- Target camshaft position for Bank 1.
- Target Camshaft Angle Bank 2
- Target camshaft position for Bank 2.
- Target Firing Angle of Torque Intervention
- No Description.
- Target Idle Speed
- Idle speed target.
- Total Mass Air Flow (MAF+Tank Vent)
- This is a combination of MAF plus the tank vent recirc total airflow.
- Warm-up Cycle Counter
- Cycle counter for the warm up cycle.
I’ll post a picture in the morning of the layout with a video on how to get it. It’s not a gauge with a sweeping needle, just a ever changing number with a memory spot below it showing your highest boost.
The video I did isn’t uploading. Click the highlighted gauge and goto manifold absolute pressure. That’s your boost pressure
800WHPSUPRA
07-19-2017 08:56 AM
