Need advise lowering my 996 Turbo
Old 08-10-2020, 02:47 PM
ROCK's Avatar
ROCK is just really niceROCK is just really niceROCK is just really niceROCK is just really niceROCK is just really nice
Hello,
I need advise on how to lower my 996 Turbo a liitle. Maybe OEM 996GT2 stance will look good although I parked next to a GT2 and it was too low for my taste.
I've seen some GT2 lower than others, maybe they have different specs for different years or maybe US cars are not as low as RTW cars...
Old 08-10-2020, 02:50 PM
ROCK's Avatar
Old 08-11-2020, 07:28 AM
Slider's Avatar
You can't go wrong with PSS10s - good all around and the height is decent.
Old 08-11-2020, 07:33 AM
HotRodGuy's Avatar
I'd recommend the Ohlin R&T over PSS10's, i replaced my PSS10's with them and couldn't be happier
that said, what's your budget?
Old 08-11-2020, 09:34 AM
ROCK's Avatar
I read about PSS-10 and as I undestand the minimun drop is 1", I was thinking dropping the car 3/4".
Old 08-12-2020, 07:30 PM
ROCK's Avatar
Can you drop a 996 Turbo without changing any parts ? I think I read somewhere (I think it was the owner's manual) that there is a bolt you can adjust the height a little ?
Old 08-13-2020, 10:24 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
Negatory on the height adjustment without parts. From what i have read the Ohlins are preferred for their ability to be adjusted to a higher ride height. The PSS10s have a very specific height range that if violated do not handle well? I went with H&R springs and B8 shocks and i am OK with them. Ended up really low and needed custom spacers to get up to GT2 height for my liking. Wish i had spent more and gotten the Ohlins.
Old 08-13-2020, 10:39 AM
Slider's Avatar
+1 - They say PSS10 is adjustable, but really they are not. There is only one setting that work. - Max high in rear, max low in front (or vice versa - I don't remember).
Old 08-14-2020, 10:17 AM
ROCK's Avatar
No budget. I've had the car for almost 20 years and counting, so I better be ultra happy with it. I think the proper height will make a huge difference to me.
I just don't want to go too low because the car looks "tired, old". I want to achieve a bit higher than a GT2 and a little lower than a Turbo.
Old 08-14-2020, 10:37 PM
'02996ttx50's Avatar
that would be the approximate of the x73 setup at -20mm or ROW height. the gt2 is probably -30mm.
the car at gt2 height does not look "old". it looks and rides as good as it gets. it's only our tired eyes ( or old sagging springs ) that play tricks.
you might consider thirdreef's suggestion of b8's and h&r sport springs for lowering and perfectly capable stability. he claims to wish for more. i wish for nothing in the handling/stance department with that set.
Old 08-15-2020, 07:31 PM
nglaser's Avatar
nglaser is infamous around these parts
How much lower is the max height for the PSS10 compared to the stock height?
Old 08-16-2020, 12:10 PM
Slider's Avatar
About 1 Inch. The new ride height is about perfect - not too low, not too high - If it were more adjustable, I would make it the same height anyway.
Old 08-17-2020, 10:25 AM
kamlung's Avatar
kamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to all
this... if you are just looking for a drop and don't need the adjust-ability... a set of springs and shocks will do it...
Old 08-17-2020, 11:35 AM
ROCK's Avatar
Sounds good.
Any specific Springs and Shocks ?
Old 08-17-2020, 05:42 PM
kamlung's Avatar
H&R springs with some bilstein B8 are a tried and true combo...
Quick Reply: Need advise lowering my 996 Turbo
