Where rims and tires sizes do all you guys that have 19" wheels?
Old 03-12-2006, 11:50 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Question Where rims and tires sizes do all you guys that have 19" wheels?
Sorry about the typos in the title, what size tires and wheels do you guys run in terms of 19" inch wheels (I'm speaking about aftermarket wheels)? 19x9 front with 245/35/19 tires? 19x12 rear with 335/25/19 tires? How wide can I go in terms of rims and tires (in terms of 19" inch wheels) with the car being lowered
Old 03-13-2006, 12:20 AM
Ruiner's Avatar
rear: 315/25/19
front: 235/35/19 or 255/30/19
Old 03-13-2006, 02:06 PM
rear: 315/25/19
front: 235/35/19
my rears are custom made.. they r 12 inches wide...
Im I want to trade or dsell mine.... pictured....
if anyone has nice 18s... i would do a swap.... Im looking for the rears to be 11.5 inches...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 03-13-2006, 02:45 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
work equips!
Old 03-13-2006, 02:57 PM
TUUNER's Avatar
TUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant future
I would be careful about using a 12 inch rim with a 315 tire size in the rear. You will not have the protection from the tire for the outer lip of the rim due to the 315 tire size. An 11.5 rim will have the outer lip protection with the 315 tire size. Please correct me if I am wrong.
Old 03-13-2006, 03:04 PM
well i have it foe 2 years .. tried different tires.... and found that yokohama avs run thin.... but then the conti sports fit well...
I need 18s cause I will have tracking issues when I get my car back and they dont make sticky tires (drag radials)for the 19s...
9.66
click to view
Old 03-13-2006, 03:17 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Markski,
Can you tell me which tires you have used and which one you liked best on the 12" rim? Thanks
Old 03-13-2006, 03:18 PM
Griza's Avatar
Originally Posted by 02barebones996
work equips!
That is one badass TT!! Great color and great rims!!!! WOW
Old 03-13-2006, 03:26 PM
Originally Posted by Griza
Markski,
the only onse that fit are the onse I have on the car... conti sport.. 315/25/19
the yokohama avs sport run 1 inch narrow....
I had both so I know... Im willing to trade for nice 18s..... Im doing a High HP upgrade and Im told I need to run on drag radial to hook.
9.66
click to view
Old 03-13-2006, 03:46 PM
Ray's Avatar
Ray
Ray is offline
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Markski, any rubbing issue with 315 con't at back? How $$ do you want for your set? PM me!
Old 03-13-2006, 05:37 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
PS2s 235/35 on 8.5J 42mm offset and 315/25 on11J with 30mm offset.
This will be a very aggressive offset.....with some fender prep for very low suspension.
'Rubbing issues' are more a function of offset, ride height, and how stiff your suspension is....rather than simply tire size.
Old 03-13-2006, 07:32 PM
Ruiner's Avatar
100% correct. My 315 Yokos were about 1/2-1" thinner than the 315 Contis (and I would assume Pilot Sport 2s).
Old 03-16-2006, 04:09 PM
DeeMan007's Avatar
DeeMan007 is infamous around these parts
I'm hearing (reading) Pirelli, Yokos, Contis...are these the main tires you guys use on 19" rims? I'm about to get my Vellanos 19X8.5 and 19X11...so which tires have you guys found out to the be the best on 19" rims?
Old 03-16-2006, 04:14 PM
20C4S's Avatar
best bet is Conti for the cost & Michelin PS2 for the performance. Yoko 315 is not DOT approved therefore very hard to come by. Pirelli is in the PS2 price range so might as well just go for the PS2.
Old 03-16-2006, 04:27 PM
DeeMan007's Avatar
Arling,
Would you run 305/25/19 on a 19X11 rear wheel and if so, what tires would you use then? Thanks!
Quick Reply: Where rims and tires sizes do all you guys that have 19" wheels?
