When is a turbo too big?
#31
Originally Posted by MARKSKI
I have anti lag on my evo 8 via a standalone ecu
#32
Originally Posted by lithium
There are many ways to spool a big turbo(s), as mentioned before brake boosting and juice for one, but if you want to get advanced, 2-step, anti-lag and other such methods exist, most are built into a standalone like EMS. All work on the same basic principle;
miss spark, retards timing, add more fuel get the EGT's way up
and that spools the turbo under no load. You can build over 20psi at starting line even with GT40's.
good for a drag car - VERY hard on the turbo. you are basically causing miniature explosions to boost the turbo.
- chuck
#33
KA uses a programable nitrous system. It is designed to activate at WOT. In addition it has two rpm pills. The system needs WOT and 2600 rpm's to activate and the second pill starts the shutdown at 4400 rpm's. These pills can be changed. When the system activates it starts with a 10 hp shot and adds an additional 10 hp shot every tenth of a second for 2.5 seconds. As long as you are at WOT, the system shuts down in reverse order oce you exceed the upper limit pills rpm number.
Yes, the turbo's do boost extremely fast. The system is very smooth.
#34
#35
- chuck
- chuck
#36
Originally Posted by 95RogueM3
Is the plan to spray everytime you drive the car? (or will you turn the Nitrous on and off from the cockpit as you see fit?)
Oh, almost forgot ............. the clutch must also be fully engauged for system to activate.
To answer your question, it can be activated at will from the drivers seat.
#37
Originally Posted by iLLM3
Now i know somewhat about stand alone, but could you explain some more how it allows you to spool up or have anti lag ??
#38
The system has some safety built-in. The fuel pressure must be at a certain pressure at all times. There is an cabin electronic on/off system ready switch along with another switch that electronically opens or closes the tank valve.
#39
Stand alones have anti-lag parameters inside which the user can modify, this includes amount of retard (up to 40%), enritchment mix, and some other small things. Read my post above to understand how it works.
#40
Chad, i am sure this has been posted somewhere, what engine management does KA run, i assume MOTEC?
#41
We are using a modified 996tt ECU. One of my requirements is the car has to pass the smog sniffer test. Without nitrous activation of course. We are running with Kats.
#42
cats? stcok ecu? With the budget of KA you could pay Magneti Marelli to write you a standalone! But seriosly, have you looked into motec and such? Its light years ahead of any "band aid" stock ecu piggyback. Once you get used to it, its amazing.
I'm not too worried about the "band aid." Depending on the turbo's we settle on she will have anywhere between 1.0 and 1.5K hp. That is 962 race trim power.
PS.......... we are not piggybacking anything. We are not using vario timing, cams or actuators.
#43
Guest
Posts: n/a
Yes, we have looked into it. Trouble is, when they plug into the port the car would instantly fail.
I like the approach that Robb is using on the cam set-up on KA!! I am going to have to take another look at my new motor build-up, since I want to run twin GT42R's on the 4.2.
#44
Originally Posted by VRAlexander
Todd at Protomotive got the Motec to work on my car and the M600 has fly by wire as well as vario cam onboard. I love the way you abbr. 1.0 and 1.5K on the horsepower!!!
I knew Todd tried Motec, however my understanding is you stayed with the modified Bosch ECU.
New motor for your tt. I'm surprised considering your 2200 lb GT40R turbo rocket. Now you really have me baffled.
#45
...New motor for your tt. I'm surprised considering your 2200 lb GT40R turbo rocket. Now you really have me baffled.
