GT700 Wastegate Adjustment Needed
Old 04-02-2006 | 07:15 PM
Originally Posted by jags911tt
From what i understand, the car will still be boosting at the prior levels, but the diode makes the car believe it is boosting less to avoid a TB shutdown. So you are actually tricking the ecu.
I have the diode in my ecu... I know what it does... I wanted to know what u know
my original question is: does the diode only bypasses the TB and does not control the WGs... my answer is YES. I tried it with 2 different wastegates and ran numerous tests... these cars need to run at 1.3 bars on 100 octane.. it a different animal...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 04-02-2006 | 07:19 PM
Zippy's Avatar
Originally Posted by Zippy
I'm going to have a look to see if I have the diode. Is it easily recognizable?
Stephen - can you answer this and save me the trouble of taking out and opening up my ECU??
Old 04-02-2006 | 07:25 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
On all packages gt640 and up a diode should be installed. From what I have heard it is possible for these diodes to blow out and then they need to be replaced. They stick out the a sore thumb if its installed. Open up your ecu and you will see it for sure.
Jags
Old 04-02-2006 | 07:28 PM
jags911tt's Avatar
So what is your question exactly?
Old 04-02-2006 | 07:34 PM
According to MIke(zippy) .. his car is boosting only 1.1 sustained... do u think its because he has / has not the diode that is causing his problem?
he should be at 1.3 bars firm.
my answer is... no/.... the diode has nothing to do with the lack of boost.. it only bypasses the TB so u can boost MORE... so once he sets his WGs correctly... he will be at a nice 1.3 bars..
On a side note, for those who are even more interested... u can bypass the stock frequency have, and hook up a greddy boost controller and have TOTAL contolll over ut boost setting.. without having to go thru what Zippy is about to do... u run low boost on pump gas(1.1 bars lets say) and 1.3 bars on 100 octane... as the wether changes so will ur boost.. so with a EBC like greddy u can adjust to change in atmospheric pressure...
thats how turbo cars are really contollered.. no its only reserved to RICE ROCKETS... ITS A STANDARD IN THE TURBO TUNING BUSINESS..
9.66
click to view
Old 04-02-2006 | 07:39 PM
jags911tt's Avatar
I don't think it could be a diode problem because without it the car would be showing more than 1.3bar
And I agree with you on that one
cjv's Avatar
cjv
Moderator
Yes .........
Old 04-02-2006 | 07:54 PM
wross996TT's Avatar
I think I'm learning more than I should about these damn cars. My mind needs a waste gate or I might diode. I still want the experts (mark, Todd, cjv, stephen, etc.) to tell me what is best for me...off-line of course.
Old 04-03-2006 | 01:32 AM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
Is there a step by step on how to adjust the wastegates anywhere? Pictures of them in the car would help big time.
Old 04-03-2006 | 02:58 AM
FAT-911's Avatar
FAT-911 is infamous around these parts
Here's a pic of the diode, very easy to see when you open the ECU cover.
Old 04-03-2006 | 12:14 PM
Zippy's Avatar
Thanks a lot for the pic. I guess I have to pull the ECU out and see what's inside. There is no point cranking up the waste gates if I don't have the diode.... I would be back to TB shut down again.
Mike
Old 04-03-2006 | 03:02 PM
jags911tt's Avatar
If you had the diode then you would be making more boost BUT showing less on your readout.
The fact your only showing 1.1bar makes me think its not a diode problem.
The diode is used when a car is making too much boost, say 1.5bar and teh car is shutting down the TB.
Your situation is that your car is only making 1.1bar. I think something else is going on with your car.
Jags
Old 04-04-2006 | 02:10 AM
Zippy's Avatar
As it turned out, I was too damn lazy to pull the sub box out and rip open the ECU. I wanted to buy a jack anyways. I gave my waste gate actuator nuts 1 turn "tighter" and am now solidly holding 1.2 bar. I've seen 1.3 briefly and had a momentary spike to 1.4 bar. I'm considering giving the nuts another 1/2 turn in an attempt to hold 1.3 bar. (Markski suggested 1.5 turns all in) I tested it out today with the temperature at a brisk 6.0'C. I was wondering if I should wait for some warmer weather and check things out before tightening the waste gates any more?
Old 04-04-2006 | 12:40 PM
Zippy, Im happy to u its working... are u sure both sides are exact(nuts turned same amount..)
Here is the problem... as temp. change so will ur boost... so my suggestion, if happy with what u have, is to get a boost controller installed... taht way u can adjust boost at ur fingertips. but u have to be responsible and not get carried away with the boost....
best to u,
mark
9.66
click to view
Old 04-04-2006 | 02:47 PM
PorschePhd's Avatar
Mike,
You have the diode in there. All the ECUs I have done get them with the GT kit. It doesn't bypass anything rather clamps voltage to the sensor to calm the spikes that occur. These boost spikes are translated to voltage spikes on from the sensor which to the ECU thinks is an error. It simply trims that spike so the ECU can see the signal properly. Don’t forget TB shut down can be caused by many things such as misfires, over limit on another sensor and so on. It is in line to protect the motor from any parameter outside the norm in the system.
George, I don't actually do the diodes like that anymore. I came up with a more stealth way on the other side of the board that looks more factory and less likely to be spotted if peering eyes looked. I say that unless I was pressed with time then I normally still board mount them without the wire.
