GT700 Wastegate Adjustment Needed
#31
Originally Posted by MARKSKI
Zippy, Im happy to u its working... are u sure both sides are exact(nuts turned same amount..)
Here is the problem... as temp. change so will ur boost... so my suggestion, if happy with what u have, is to get a boost controller installed... taht way u can adjust boost at ur fingertips. but u have to be responsible and not get carried away with the boost....
best to u,
mark
best to u,
mark
Mike
#32
Zippy,
You should really adjust the wastegates properly. If one turbo is set different than the other it will be working harder than it should and may risk failure. I can send you the tools you need to do it properly if you like. Do you have a small hand operated bike pump?
Tom
Tom
#33
I dont this Zippy has his turbos off... I just think he needs to make an adjustment..
Yes u can set to low boost... run pump gas... switch to 100 octane via flashloader, switch to high boost setting hy hitting a button... crank it up to 1.4 bars... or so... but on that I would contact ut tuner and make sure waht level is safe on ur kit...
this is hoe most turbo cars should/are run.. but then again IM not ur tuner so I cant really tell u....
I do know that protomotive does do it liek I say... but then again.. each tuner is different...
mark
mark
2001 996TT 3.6L and stock ECU
#34
Originally Posted by K24madness
Zippy,
Tom
Tom
Thanks for the input. I would like to do this as accurately as possible.
Mike
#35
Mike u leave the turbos on...
04-28-2022 12:38 AM
Fadi
08-21-2015 03:43 AM
