The Evo TT is now the Evo GT2!
CJV, I didn't modify the AWD in any way. I actually enjoyed the AWD and was able to push the car pretty hard as a result of having the safety net of the AWD. I'm sure if you've gone this route with your car it has improved the AWD system. I really didn't have an understeer problem as many have with this car because of the ability to adjust spring rates, camber, toe, sway bar, bigger/grippier slicks, etc. Have you made the changes you mentioned and how do you like them?
Jean, You're right on the money with all your comments. In addition the ability to go to a taller tire in the rear will also be beneficial. Having to match the front and rear tire diameter's with the AWD keeps the rear tire with a fairly low profile. As you know the benefits of having a taller tire adds a larger surface for additional heat loss.
No secrets on the suspension. I actually purchased most of the GT2 parts from Ric Knab at Suncoast Motorsports and the performance parts came from Evolution Motorsports. They were both extremely helpful.
Most important part for the conversion as Jean mentioned is the LSD. If you don't add an LSD you're wasteing your money/time, all the above.
More detail on the suspension changes: GT2/3 wheel carriers, GT3RS lower control arms, GT3RS adjustable rear toe links, GT2/3 front sway bar, GT3R rear sway bar, Moton shocks, eibach springs( spring rates 1200-1500 depending on the track, Motorsport LSD, etc. With these items the ability to adjust your setup is unlimited much like that of a Cup car.
Unlike Sebring, I'll post a video of a lap at Road Atlanta to show you how the car runs/handles in 2wd.
Changes for Mid-O will be to run Dunlop 265/650/18 fronts and 300/660/18 rears. The 300's are equivalent to my current Pirelli 325/650/18 in width.
Rick
Rick
Buddy, Probably a dozen times I've asked that myself. I started converting the car to a street/track car and progressed to where it is today. It's kind of the same idea with Evolution and GIAC tuning, you always want a little more power.
I've ended up with a 996 Cup beater and fairly close to a 997 Cup beater depending on whose driving the 997 and the track. The car has really become a test for many different part manufacturers. The car was built by FABCAR out of Indy, using Kelly-Moss CF body panels, with a dose of suspension components from the Racer's Group, with the last parts coming from Farnbacher-Loles.
I plan on finishing the car up this fall/winter, after the racing season, with a trip to Kelly-Moss for some additional CF panels/nose/rear decklid/rear quarters/ etc.
Tom, In World Challenge GT, the GT2 and TT compete against 996 and 997 WC prepped Cup cars. In PCA I run GT1-R which is an unlimited HP class of turbocharged cars, whereas 996's and 997's run in GTC3 & GTC4 respectively. So, no, we're not in the same class but typically we're in the same race group, on the track at the same time.
In GT1-R it's typical to have a 700-800hp Porsche weighing 2500lbs or less on big slicks with huge wings and good down-force, that's what I'm up against and is very challenging for me.
Rick
Rick
Legally yes, it has Collector plates here in Ohio. However the clutch is like an on/off switch(full-race clutch). The interior is out of the car. No A/C or heat. CF would be bad in a wreck(splintering). The roll cage is probably not the best idea in a street car.
So yes, it would make one hell of a street car but be a little uncomfortable as a daily driver.
Rick
Rick
Next stop is the PCA Race at Mid-Ohio May 13-14, if anyone is in the area please feel free to stop by. I think I'll try and run the GT2 in the Sprint Race and an '88 930 in the Enduro.
Tom, Glad you're enjoying your X50 TT what a good street/track car. I have a '02 silver X50 TT that I use for the street but everytime I look at my race car I want to lower and stiffen the X50.
Rick
Rick
The rims in the AV are Champion. I needed to go to a more custom wheel for the track so now I'm using Forgelines. The Champions ended up on my street car.
I've not raced my car in WCGT yet because I haven't felt it capable of a top 5 finish. I hope to run it at the WCGT event in the fall at Road Atlanta if not sooner. For now I'm running the PCA events as tests for upcoming events. However, I'm finding out that the PCA events are a blast and typically there is little damage to cars compared to WCGT.
There are a couple of other teams that haven't been successful in finishing in the top 10 but with being able to lose the AWD things are looking brighter.
Also the prize money in WC is not that great considering how much you spend out of pocket. Most of my expenses are out of pocket at this point.
Rick
Rick
Rick
Rick
http://www.gilhartmotorsports.com/DSC00571.JPG
Try the above link. I believe they're the RG5's. I got them in 18 inch so I could mount slicks for the track.
Rick
Rick
irish100p
10-24-2015 09:37 AM
