Boost pressure timing valve Help
Old 04-13-2006 | 05:37 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Has anyone seen one of these valves go bad intermittently? If it did, would it intermittently limit boost to .4 bar without causing a CEL? Is there any way to test it other than replacing it? Thanks - need info for Buck80
Old 04-15-2006 | 10:03 AM
rmrmd1956's Avatar
Where are all gurus?
Old 04-15-2006 | 05:17 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Not exactly sure what a boost pressure timing valve is, are you talking about diverter valves?
Old 04-15-2006 | 06:05 PM
rmrmd1956's Avatar
Here are diagrams of the switch.
Old 04-15-2006 | 06:58 PM
M3CAB's Avatar
Thanks, but I do not know, but am sure some one of the pros will chime in and help out. Suggest PM'ing Alex.
Old 04-16-2006 | 09:27 AM
PorschePhd's Avatar
Yes, I have seen them go bad. They will eventually throw a code if it continues to happen. Any error that would close the throttle body will throw a code immediately if not in time. The valve can be tested with the PST2
Old 04-16-2006 | 11:16 AM
Its another fancy name for a boost controller.... BTW- thats exactly the part u disconnect to hook up a Electronic boost controller like a Greddy...
that way u have controll over ur boost...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
04-28-2022 12:38 AM
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
BlackMarketRacing
12-08-2015 01:49 PM
The Oss
08-24-2015 08:19 PM
Quick Reply: Boost pressure timing valve Help
