Heads Are Ported, Polished and Flowed, and Larger Valves Are In: 324 CFM
#31
Originally Posted by Craig
I am not using stock cams. Nevertheless, I am not going above 8k rpms. Rather, I am only raising my rev limiter to 7500 (from 6800).
Craig
Craig
You have my interest up now. To date S Car Go Racing is the only tuner that I am aware of that has anything other than a stock intake cam. I know others use the GT3 exhaust cam with one exception at that is FVD who doesn't play with the intake cam but has another exhaust cam other than the GT3. I believe they call it a GT2 cam set. This GT2 cam set does not utilize extented RPM ranges though.
Any way, the best of luck with your project and again thanks for sharing your flow numbers with everyone.
#32
Oops, blinded by the light in those cavernous passages.
Craig, what are you going to do with 1100 hp? This will certainly be a 9 second street machine that nobody will touch.
#33
I am using the OEM intake cams. I am using the following EVOMS exhaust cams:
Craig
I understand what you are using. They will work out great for your desired rpm range. In addition, maintaining the vario cam and timing will make life alot easier in drivability, maintainence and tuning.
Craig
#34
Craig
#36
Im using GT3 cams(thanks CJV) gt3 RS heads... no vario cam and I dont want to say anything but will rev very high...but not as high as Chads... todd is finishing up with some fancy cam and piston hold down tools because they do not exist... I have pics but Im going to hold off for now... we also got our hands on a World Cup Challenge plenum... never seen one myself... but he really likes it...
He also said that my limitation now will be the gt35r compressor...hmmmm. bigger???
2001 996TT 3.6L and stock ECU
#40
Originally Posted by Phoenix
Craig,
What exactly did 9ff do to your transmission?
Craig
#42
#43
well, we got our hands on some gt3rs heads and thanks to scargo and Chad we have a new set of gt3 cams.. bought the lifters.... and all other stuff needed... Todd has done the research and prepping the heads... it would have close to done but we decided to go all out... Todd really hooked me up.. and maybe sometimes he is hard to get a hold of.. but he is the most down to earth person I ever met... and very smart. Im going to say 1 month.
#44
9ff replaced every gear with stronger gears, installed more and stronger clutches, installed more/stronger friction plates, and added a Mocal transmission oil cooler with custom piping.
Craig
Craig
Mike
#45
Originally Posted by Zippy
Did you change the ratios? I know some 6 speedster stretchin out 1 & 2 to make them more usable. Because the tip uses different ratios, was this not needed?
Mike
Mike
Craig
