Chances of 997TT VTG Turbo tech. on a 996TT?
Old 04-30-2006, 06:58 PM
glpdx's Avatar
glpdx is infamous around these parts
What are the chances that someone like EVOMS could figure out a way to put VGT Turbo technology on the 996TT, once it comes out? Is it premature to ask this question or is it completely impossible because of drastic differences in the ECU, etc? Most likely, I'm guessing EVO will just focus thier energy on the 997TT, but I was curious anyway. I'm afraid there will be no more improvements made to the 996TT once the new model is available to be tinkered with. Thoughts? Guesses?
Old 04-30-2006, 08:02 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
If the technology is worthwhile, enterprising tuners will offer it to everything from 930s up. Remember, these have been around for awhile and no one was interested in them until now.....so lets see how the 997TT is treated.......but God is it ugly....
Old 05-01-2006, 03:26 PM
tom kerr's Avatar
I think some of Kevins turbos that are modified performance wise may still be better than a stock 997TT....but time will tell!
Old 05-01-2006, 03:35 PM
K24madness's Avatar
K24madness is infamous around these parts
Sorry to say it will be much eaiser for us 993 folks than you 996 guys. If anyone can do it on the 996 it will be protomotive.
Old 05-01-2006, 04:20 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
why do you say that?
maybe i'm missing something obvious, but it's just programming the ECU to account for the quicker spool-up. ????
- chuck
Old 05-01-2006, 07:11 PM
glpdx's Avatar
993, shop, whatever. That's not the issue here. I understand the point that VGT has been around for a while and isn't a revolutionary technology. Let's just say, Porsche managed to "re-invent" the VGT to be worthwhile. I'm trying to imagine how much of that could be related to the turbo generators and how much to some proprietary ecu programing. If it's in the turbines, could they be slapped on to a 996? Again, I can see how it's too soon to tell. it's just fun to think about.
Old 05-01-2006, 08:16 PM
carendt242's Avatar
my guesses: yes, you can slap the VTG's on a 996 since it's the same engine as 997. theoretically, w/ programming, you'll get better spool & mid-range; however, will it be worth the $$$ to buy these from porsche?
if you want to go higher than 550-600hp, you'll have to revert back to our turbo selections now since no one makes a bigger VTG (that i'm aware of.)
- chuck
Old 05-01-2006, 09:59 PM
glpdx's Avatar
Yea, you're right. It's exactly reverse what someone else said in one of the other threads about modding a 997TT. Now that I think of it, that's where I got the idea (or problem for that matter). So, I guess what I'm wondering, could someone take a 997tt turbo and "grow it" for both the 997 and 996 TT's. I'm thiking the new complexity of the VTG and the imense reprogramming of the ECU could be prohibitive. Nevertheless, I think you're saying "if someone builds it, they can be used". Right?
Old 05-01-2006, 10:24 PM
ebaker's Avatar
ebaker is infamous around these parts
I don't see any reason you can't enlarge the compressor and clean up the turbine on the 997TT for more power. I don't have any idea how you can control the variable nozzle on the 997TT turbocharger with a 996TT ECU. The 997TT has other changes, such as continously variable intake valve timing, that would make it difficult to use a 997 ECU on a 996TT. Maybe someone can make an external black box controller that simply controls the turbine nozzle based on RPM or exhaust back pressure, independent of the ECU.
I wonder if the 997 turbine nozzles are 2 position or continously variable?
edit: I just remembered the the variable turbo vanes have to be periodically cycled through their complete range or motion to "sweep" off any carbon build up.
Old 05-01-2006, 10:34 PM
K24madness's Avatar
The main problem is how you control the VATN vs internal wastegates on the 996tt. The turbos have been around for years but the materials where not able to cope with the heat. Now they can.
I expect an aftermarket boost controller will do the trick. Problem is they are not made yet. Once they become available I expect we will see them on our cars. The comment about being easier on my 993tt stems from the less complicated electronics and how the ECU would react to the new boost curve.
Old 05-01-2006, 10:43 PM
ebaker's Avatar
Does the 997TT have internal wastegates?
Old 05-01-2006, 11:25 PM
K24madness's Avatar
No it has no wastegates at all. The VATN is a variable turbine design that can control boost without a wastegate. This is why it will require a unique controller to manage boost.
Old 05-02-2006, 03:56 PM
carendt242's Avatar
ahhh, that was the "obvious thing" i was missing
Old 05-02-2006, 04:05 PM
Fanman's Avatar
Fanman is infamous around these parts
Also, are we positive the new 997TT turbos are K16 sized turbos ? Would love if they came out with standard K24 sized VGT turbos on the 997 TT.
Old 05-02-2006, 04:16 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
They save that for the GT2
Quick Reply: Chances of 997TT VTG Turbo tech. on a 996TT?
