Motul 5.1 or Motul RBF600 Brake fluid ?
I am doing some lapping once a while, (about 10 times in a summer, 10 full days). Wich brake fluid would you recommend ?
Car is a 2003 996TT
Car is a 2003 996TT
Castrol SRF is in a class by itself-the best racing brake fluid you can buy. Second place would go to the Motul Racing, at about half the cost. Third would go to ATE Blue, at half the cost of Motul. The Motul 5.1 would be my fourth choice (lower wet and dry boiling temperatures than the ATE). Given that you want to at least bleed the calipers after every lapping day and you can't (or shouldn't) re-use leftover fluid from an open container, the Castol gets even more expensive, but nobody ever said this was a cheap hobby.
No it's not a cheap hobby
But I know a place that ships pretty quick... cheapoilstore.com .. try this link
Motul RBF600 brake fluid
AP Racing 600 is also an excellent choice.
Bish
Bish
Last edited by thebishman; 05-13-2011 at 01:02 PM. Reason: Should have written 600 and not 650 as I initially did
Feelgood MD
03-24-2016 09:35 AM
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ECS Tuning - VW
09-02-2015 09:03 AM
