fuel pressure regulator
stock I say $520 HP. 5 bar is 600 to 640 max.
I have a secret that todd K shared with me so I know where to get them for $80.
u can always go with the regulated one- $230
2001 996TT 3.6L and stock ECU
I'm a little confused. Do you upgraded the stock FPR to flow additional fuel when OEM injectors are being pushed to thier limit? OR is upgrading the FPR required ALWAYS at higher HP levels - including situations where fuel injectors have been upgraded?
Originally Posted by ebaker
Do you have to re-map the ECU if you change tos FPR to a higher rail pressure?
I ran high 12s afrs at 1.3 bars and when I changed to a 5 bar I dropped to high 11s... which is great... you will simply run richer which robbs power but keeps ur engine nice and cool. which one would u prefer?
Originally Posted by MARKSKI
form what I know they use the 5 bar on both- stock injectors and pumps pushing 600 hp or so as welll as in ur 700 hp package utilizing bigger injectors and pumps... the 5 bar increases the pressure but not the volume.... so u need bigger pumps and injectors.
I believe they use a regulated FPR. they have to order to compensate for the increased volume.
Raising the pressure should richen the mixture during part throttle cruise. Does the ECU have maps it can switch to to compensate for the overall increased injector volume during part throttle?
You typically use a 5 bar when the injectors are nearing a high duty at 3.8 bar (stock pressure) By increasing the pressure you increase the flow.
The stage 4 kit does not need it. A 12.1 at WOT and at full boost does not require or want a lower AFR. The 700 kit uses pump and injectors and does not need the 5 bar.
You do not put a 5 bar in just to put a 5 bar in. If you do it on a kit that does not require it and change nothing else you will loose HP and be too rich.
its the evoms GT640 thats requires it.
