Replacement Battery?
Old 12-26-2003 | 09:34 PM
Pistol's Avatar
Pistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these parts
Hey all
I just had my car jump started for the 4th time in its 2.5 year life. I was curious on what the reasons were.
I drove over 200 miles on monday and left the car in my garage till this morning. I do admit the garage is not heated and is a bit frigid, but my BMW has no problem being left unattended for in this cold garage. Is this a problem with the batter?
Is there a replacement battery that I can purchase? or are all batteries like this factory one and will need to be stimulated every other day?
Also, whats the best lightweight battery for our cars and where can I get one for a good price?? Thanks
Preeth
Old 12-26-2003 | 10:03 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
If it's dead, replace it with a battery of like kind and quality as the OEM. Always remove the key from the ignition since that will drain the battery, also I recommend using the porsche battery maintainer(trickle charger) when the car is not driven 3-4 days or more...
http://e-partssales.com/Merchant2/me...Code=POTE996CC
Old 12-26-2003 | 10:06 PM
Pistol's Avatar
Thanks Rockitman!
By the way, I test drove a GT3 today at Paul Miller in NJ. OH MY JESUS
ALL I CAN SAY IS
JESUS
good luck with the car. hope u had a good trip from AWE and a good xmas. Have a good new years sir!
Preeth
Old 12-26-2003 | 11:21 PM
ebaker's Avatar
ebaker is infamous around these parts
My 2 1/3 year old battery recently died, I had it replaced under warranty. I spent less than 45 minutes at the dealer. If they think you don't drive it regularly they may not warranty it. If you have to buy a battery get an Optima, they are widely available and save some weight (20#?). They appear to last about twice as long as conventional batteries and cost about $100. You have to get a slightly longer ground cable and drill some holes in the battery mounting plate. With a good battery your car should start after sitting a month or so from what I have read. Make sure you didn't leave the overhead interior light on after your trip.
Old 12-27-2003 | 07:36 AM
cjv's Avatar
cjv
Moderator
Griots Garage www.griotsgarage.com makes a "Battery Drain Connector" that connects to your battery. It is very small. What it does is electronicly disconnect your battery when the charge level gets to the charge needed to start the car. That way when you get into the car it always starts. In addition your battery never completely drains. I believe the cost is about $70 and installs in about five minutes.
Old 12-27-2003 | 08:37 AM
viperbob's Avatar
viperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud of
I use a dry cell Odyssey PC925. 23 lbs, and it can sit for weeks at a time and start great.
Old 12-27-2003 | 09:35 AM
cjv's Avatar
cjv
Moderator
viperbob,
That Odyssey battery is a little over thirteen pounds lighter than the stock battery. The Odyssey battery we are using is about twenty-eight pounds lighter and I'm sure it would not hold a charge as long.
Old 12-27-2003 | 11:47 AM
Pistol's Avatar
Thanks for all your help guys
Have a good New Years!
Old 12-27-2003 | 03:53 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Just put a new battery in my truck today, nice peace of mind for the winter.
04-28-2022 12:38 AM
pwdrhound
09-16-2021 02:27 PM
DetomasoGTS74
11-11-2015 09:01 AM
OldBoldPilot
08-24-2015 04:00 PM
DSCOFF
08-23-2015 01:22 PM
Quick Reply: Replacement Battery?
