In shock...474hp at the dyno
#61
Mark and Marty, after talking to the guy who owns the dyno...I am pretty confident the dyno is fine. The problem is the correction factor. So I will use uncorrected numbers to compare before and after. The mods are done today anyway ...just a little break-in time and then....
#62
it will be interesting to see what it will do after u put the bolt ons.....
good luck,
mark
good luck,
mark
2001 996TT 3.6L and stock ECU
#69
New numbers seem exactly right. Didn't you say bolt on s were on already? What fo you think? If it is kevins new stuff you may still be breaking in. Don't shortcut the brak in of a zero clearance turbo or it will not last. Let us know what you think. Good luck.
#70
Yeah, I feel a little better also. Don't have the car yet...probably next week. Found a couple of minor things to fix while we had it apart...and then doing some regular maintenance stuff...then, as you say a nice easy break-in for the first 200 miles. After that...we'll dyno agin!
#71
I had Kevins stage 2 turbo's and did 100 mile break in. After the first 50 miles I slowly added boost. Obviously with the 100 miles you should do at least 5 shutdowns (eg driving the car and shutting her off)
Josh/AWE
04-02-2020 05:38 PM
10-02-2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
