HELP - Codes
Old 06-01-2006 | 12:52 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
HELP - Codes
I was driving my car hard today. Stomped on it in 2nd and power cuts off. The car is still making boost and drives normal. But the P0102 code is on. I tried reseting it and after I restart the car its on again. Is this a blown MAF?
Jag
Old 06-01-2006 | 12:58 AM
shiggins's Avatar
Official Dipshit 2006
shiggins is infamous around these parts
did you try UP UP DOWN DOWN LEFT RIGHT LEFT RIGHT B A START?
Ahh, childhood.
Old 06-01-2006 | 01:00 AM
jags911tt's Avatar
Ahh, childhood.
WTF -
Old 06-01-2006 | 01:09 AM
shiggins's Avatar
I'm sorry, I shouldn't have done that. You're thread title reminded me of it. It's a code to an original Nintendo game, I can't remember which one, but that code seems to be stuck in the head of anyone who ever had a nintendo. You're about my age, if you had a Nintendo, you'll recognize it.
Old 06-01-2006 | 02:17 AM
kunal's Avatar
kunal has a spectacular aura aboutkunal has a spectacular aura aboutkunal has a spectacular aura about
Ahh, childhood.
The good ole days of Contra!! I remember using that code back on Nintendo and Gameboy.
Old 06-01-2006 | 10:32 AM
wross996TT's Avatar
P0102 "115 Mass Air flow sensor - Below Limit."
Old 06-01-2006 | 11:07 AM
ebaker's Avatar
ebaker is infamous around these parts
9P0102
115 Mass air flow sensor – below limit
Diagnosis conditions
Engine running
Battery voltage greater than 8 V
Possible fault cause
Open circuit
Short circuit to ground
Mass air flow sensor faulty
In the case of a fault, the PSM is switched off.
Affected terminals
Terminal III/23
Diagnosis/troubleshooting
Note!
Work instruction Display OK If not OK
1 Check wiring from MAF
sensor to DME control
module for continuity.
Remove connector of MAF sensor
Connect special tool 9637 to
wiring harness (DME control
module connector).
Measure resistance between
special tool 9637 Pin III/23 and
MAF sensor plug Pin 5
0 - 5
Step 2
Repair wiring harness
End
2 Check wiring from MAF
module for short to
ground
module connector).
ground
Step 3
End
DME 7.8 DME 7.8
3 Check signal from MAF
sensor
Check voltage signal from MAF
sensor with ’Ignition on’ (with
Porsche System Tester 2 in the
’Actual values/mass air flow’
menu, or with a voltmeter and
special tool 9637).
0.9 to 1.1 V Replace MAF sensor
Step 4
Start the engine 1.2 to 1.5 V
(at idle speed)
End
4 Clean air cleaner and
replace filter element
Clean pure air side of air cleaner
(extract dirt, do not blow out
with compressed air with mass
air flow sensor installed)
Replace filter element
End
Old 06-01-2006 | 11:17 AM
jags911tt's Avatar
So does this mean a blown maf?
Old 06-01-2006 | 02:51 PM
jags911tt's Avatar
Fixed BAD MAF
Old 06-01-2006 | 03:08 PM
Zippy's Avatar
Ebaker - you're the man! Come on guys, give hime some POINTS! Another technically detailed, helpfull post!
Old 06-01-2006 | 04:06 PM
jags911tt's Avatar
Yep thanks Guys
Mathme
Cayenne 958
03-23-2016 12:47 PM
PelicanParts.com
997 Vendor Classifieds
10-05-2015 02:07 PM
10-02-2015 03:23 PM
nagual911
10-01-2015 02:52 AM
