Dynoed the GT2 today
#61
All he has to do is get bigger fuel injectors and higher volume fuel pump and he will be giving that Evo700 a good run. All that and no internal work.
Honestly I didnt feel that much lag when I had the car after Protomotive did the work and didnt feel like it was lagging badly at all. All I felt was the constant rush of power and the rear end wanting to slide on me when shifting to 3rd until I got the tires warm. I was told that if I was running race fuel to turn the boost up to 1.3bar even a bit higher and dont know if Joe did that when he dynoed it.
All I can say is that before and after were like night and day, the car was sick fast stock but after the work it was ferocious. I have never driven a Evoms 700 Porsche so all I can say is what my car felt like to me "seat of pants".
I can only imagine what VRAlexanders, Craigs, and soon Markski's car feel like.
Bajo
Bajo
#62
Originally Posted by RennTechV12
I can only speak about the cars that I have driven, but I know that I beat up on GSXR 1000s all of the time in the GT700, the car trapped at 136 in AZ with a DA of 3100ft on 19s. The GT2 version will be all that much stronger....
All on STOCK internals
nice run in with that bike when you gave mike a ride.. haha that was nice..
that gt2 is nice.. congrats..
#63
Originally Posted by Jean
RenntechV12,
You trapped 136mph? Wow, 136mph is certainly very fast! So the GT700 seems comparable to Divexxtreme's performance, which makes sense, I would say about 600-620FWHP.
Cheers
Cheers
#64
Bajo
Bajo
Maybe Sharky can chime in here about the spool up of the GT700 vs. the K24s.
#65
Originally Posted by MARKSKI
I have driven cars with gt28rs and 30rs on a 2 liter motor so I know the spool up... we use them all the time on the evos...
Garrets are great turbos.
#66
Originally Posted by VRAlexander
All I can add to this is AIRFLOW...or should I say HEADWORK!!! I can spool .7bat by 3100RPM's and full boost 1.7+bar by 3850RPM's, so take into consideration that the REDLINE is at 8000RPM's, you now have a 4150RPM powerband....so when you get out of first gear..you are under full boost for the other 5 gears...Headwork, headwork, headwork....Craig would agree with his experience of McKenzie's work.....
Attachment 36423
Picture of one of my 996tt headports
Joe,
I am willing to bet that if you left your combo how it is and gave the heads to McKenzie for an extreme head work job, you would gain over 100+hp..
Attachment 36423
Joe,
#67
#68
Craig
#69
Originally Posted by Craig
I don't have enough seat time yet to comment regarding how the head work impacts spooling. I can, however, validate that the head work adds a tremendous increase in power. I will post more about this later, but at present, it appears that head work (e.g., porting, increasing valve sizing) is a huge source of power that most people have yet to tap into.
Craig
Craig
#70
Originally Posted by sharkster
It's night and day... It's hard to describe but I'll try to do this from a GT2 - perspective rather than TT. From the few GT2s I've driven with the GT700 turbos, the spool up start about 500rpms sooner... not only sooner but harder. Umm wheels spin in 2nd and then a little in third. With stock K24s obviously there's more lag and when the turbo hit it feels less luck a punch in the back (this is with a 600HP kit that I'm comparing it too) and you spin a bit in second and the car feels less threatening over all. As I said in another thread any GT2 with a GT640/700 scares the poo poo out of me.
#71
Originally Posted by 9Eleven
So for us mere mortals out here. The 600 kit would probably suffice. Am I right? I've got to tell you. I can't wait to get my 2, this HP talk is giving me a woody.
#72
You're likely a far better driver than me anyways, ..
#73
Attachment 36423
Joe,
Attachment 36423
Joe,
#74
Thanks for the compliment. You're a class act. I do have one question. Can a bad alternator have an effect on boost/power?
If the voltage was/is low enough it certainly could? You'd need to hook up a voltmeter to it...
#75
Originally Posted by LUIS95993
Stupid question: Can GT3 heads benefit from a Mckenzie head job as well? I know that the turbos' can benefit more but some folks have used GT3 heads in their turbos as well. So, can my NA GT3 gain considerable hp from this?
GT3 heads flow more than OEM TT heads. That being said, there may well be room for even more/better flow from a GT3 head.
However, I am not sure how much of a gain would be achieved. In a TT, the gains are realized because the larger turbos push more air than the OEM heads can efficiently/effectively flow, such that the heads restrict power. I don't know if porting TT heads in conjunction would K16s would provide any meaningful gains, as the OEM heads likely can flow the maximum air pushed by the K16s without restriction. Likewise, if the GT3 heads can handle all the NA air flowing through them, I'm not sure if porting the heads would produce meaningful gains.
In other words, I am not sure.
Craig
