MPSC Rock!
#47
I have never seen 1.4 on MPSC's on a flat turn in about 40 different cars and about10 different tracks. I mostly look at AIM data and only a few Motec systems, but the few Motec's I looked at were consistent with the AIM data. Most of my data is on Porsches. Thus, it is highly likely that your data is wrong. If you don't believe me, ask the professional data anaylysis engineers at Precision Automotive Research (yes they do this for a living) and they have thousands of cars on most of the US tracks.
On my car and most similar cars, I can prove 1.1 is the lat g limit as I can present data including spins, where ... you guessed it, the peak lat g was about 1.1. ;(
#48
Originally Posted by ColorChange
Actually, I have analyzed Chris's data and it shows that on normal turns (no banking), normal tracks, normal cars (no downforce), about 1.1 lat g max for MPSC's is typical, 1.3-1.4 lat g max for slicks.
#49
Jean: Banking has a large effect. That may be the difference in our data. Supercups will also show some downforce, especially if over 80 mph. 1.7 is really high on a flat turn. How fast? I think df or banking has to be involved here even on a highly prepared car.
#50
I have three questions for the experts here.
1. Isn't "banked turns" generate vertical Gs and not lat Gs? On a GPS system would show Lat G but on a in car logger, that shouldn't show up right? Unless the logger is combining the Gs to give total G.
2. I remember reading somewhere that 0.02G is "significant" difference between the cars being tested in the mags. So shouldn't 0.1G be really significant when it's only a tire change?
3. Does the graphs by ColorChange shows that the driver is incredibly inconsistent? Seems on MPSC, the driver is a lot more "jerky" while on PS2 is smoother. A graph like that could demonstrate "hard data" to compare tires?
I have both PS2 and PSC, and I could attest that PSC is much more responsive and grippier.
TexZ
12-01-2015 01:29 PM
