My Gas Gauge Isnt Working.. Any Suggestions?
Weird, it could be a blown fuse that shuts the gas tank to its reserve with a flap inside the tank. My guage didnt work and after the reserve was used up i could only put 5 gallons in until it ran out of gas
Found out it was a blown fuse, that simple but such a PITA!
![Frown](https://www.6speedonline.com/forums/images/smilies/frown.gif)
You know, my gas gauge has been acting up like this too recently. Last week, as the low gas light came on I filled up the car (I know I did as it slightly overflowed a little) and the gauge only moved to 3/4 of a tank. It went down as I drove the car and when it got to a 1/4 of a tank I filled it up again and the gas gauge moved to Full so I thought everything was ok. Now, after driving over 100 miles, the gas gauge has not moved off the Full reading and the computer is tellin me that I have a little under 300 miles to go. Any ideas what the problem is? Fuse maybe?
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
alot of times if the gas gauge is wacky, you can disconnect the battery for about 15 minutes and reconnect, this help reset the computer, it has saved me money from going to the dealer, unless it's a hardware issue.
sdg1871
12-24-2015 12:22 PM
jpik2003
09-10-2015 05:18 PM
