Lag vs. HP for Various Turbos
OK, looking to do an ECU flash, and thinking about upgrading turbos at the same time if financially feasible. But coming from the V8 world, still not used to punch throttle.......and having to wait for power. Options for me are:
1. Keep the K-16s - The flash will take me to 500 hp (Stage 2 - but already set with the exhaust) and 0.9 bar boost. I assume the lag will be the same as it is now, correct? The exhaust definately decreased it (modified X-50 ear shredder)
2. Buy K-24s - Have seen these on sale for $2,500 a pair (new). HP is around 550, but I hear different things about the lag. Would they with the ECU tuning still be laggier than a standard car with K-16s?
3. Buy K-16 hybrids - IA has these for $850 ea. They claim they will support up to 600 hp, but I've never seen a dyno, or know what ECU tuning package would be used for these. I assume these with the ECU flash should be equal or better lag-wise to standard K-16s. Anybody have further info on these?
Anything past that really isn't what I want to get into right now.
Thanks for the help!
yep have zero clearence 16's (kevins) am very happy with them paired them with s cargo headers and a euro pipe loud, also ecu reprogram ... i would keep the 16 ' well get the hybreds from kevin they spool up faster.good luck. remember air in air out tthe faster taht happene the faster you go!!
Steve,
Have you performed a dyno test on your car? I think IA does use Kevin's hybrids, but for $850, not sure they would be zero clearance......thought those were bigger buck turbos.
I strongly recommend the hybrid k16s. I used a set for over a year and they performed GREAT!!!
Craig
Craig
Hybrids all the way... evoms gt640 or k24/18gs. Kevins hybrids are very nice too.
2001 996TT 3.6L and stock ECU
Craig
Craig
Originally Posted by Finality
Just wanted to jump in, whose Hyrbrids should we go for?
I keep hearing each hybrid is different and pretty much dependant on builder....
Most tuners on this board have good product.
Originally Posted by Shark01
What software program did you use with these?
Craig
Here's a question for the gurus:
What are the tradeoffs with hybrids? There has to be
something on the bad side, else KKK would make them
and Porsche would use them. I understand that hand
work can optimize clearances, but a k16/k24 hybrid
is being described as 'low lag like k16, higher boost'.
I am cautious enough to ask how I would be paying for
the 'free lunch'...
Joe
the 'free lunch'...
Joe
Joe,
I wouldn't consider myself a guru, but I have been through this and here is my take. I ran stage 2 (RUF exhaust / FVD ECU) for 3 1/2 years and was extremely pleased with the performance. This package increased power and reduced lag due to the 100 cell free flowing exhaust and tuning parameters. I often thought of upgrading and finally decided to go through with it this spring. After some research, I decided K16/24 hybrids best suited my goals. There were several options...standard K16/24, low clearance K16/24 (.003 vs. .008 stock), zero clearance K16/24 (require strict break-in or they are ruined) and K16/24 low or zero clearance with 1.2 bar wastegates (either heavier spring version of the originals or custom billet wastegates). I choose the K16/24 hybrids with .003 low clearance (supposedly an exact replica of the RUF turbo - low clearance is a major ingredient of how RUF gets their power) combined with the custom billet 1.2 bar wastegates. There seems to be the slightest increased lag over the stage 2, K16 package, but not more than the stock K16 performance. So, IMHO, the answer to your question is: the trade-off is a little more lag for a little more power - no free lunch as you put it. Since the additional lag is so slight and about the same as stock, it is not a major issue. The power/power delivery is significantly enhanced over stage 2. I added the ported, polished and ceramic coated headers and Evo silicon boost hoses (the car blew the hoses off on the first test run) at the same time as the hybrids, so my experience reflects the results of the sum of all these components together. I have now driven the upgraded car for a month or so and I can say that it has never been as enjoyable and I would not chose to return to any of the previous/lesser levels. The car also sounds a little more business at WOT - my wife driving beside me in an SUV commented that the car is much louder...and said it sounded like a jet taking off (I have the RUF quiet exhaust and inside it sounds the same as before, just a louder woosh at WOT - but nothing offensive at all). Hope this helps.
