Brake caliper removal?
Hey guys,
I need to remove my brake calipers. Sending them to Eric Sandoval How difficult of a job is that? Does anyone have any links to how to instructions? Any help would be greatly appreciated.
This is a fairly simple job. A couple main bolts hold the caliper on and then you need to remove the brake sensors and brakelines (unscrew and block them). I am not sure if there are any instructions online. Hope this helps.
TCM is dead on. It's simple but the most important thing is KEEPING DIRT OUT OF THE BRAKES. You don’t want dirt getting into the pistons. Clean everything EXTREMELY well before disconnecting anything. Then, make sure you have good clean plugs for the ports.
ECS Tuning - VW
08-20-2015 03:07 PM
