Craig how's that beast running?
#46
Originally Posted by Craig
Thanks Marty. Bumps in the road are inevitable with cars of this nature. VRAlex’s car took two years to build and, even after it was initially “finished,” there were several “bumps in the road” that had to be resolved. I am not at liberty to discuss the particulars, but suffice it to say that it was not smooth sailing from the very first drive. CJV’s car has been under the knife for two years, and he still has not resolved all the issues. Markski’s car has been in progress for almost six months. As the learning curve increases, subsequent cars have the benefit of prior experiences.
As I previously mentioned, my car is not the first 996TT to blow a head gasket. Other respected tuners, who I will not mention by name, have experienced the same problem. Fortunately, there are solutions available and, just as the other tuners have solved the issue (with o-rings), so too will EVOMS. I am particularly impressed that EVOMS did not simply apply the o-ring fix utilized by others, but also undertook additional measures, discussed above, to ensure a comprehensive solution. EVOMS will do everything possible to ensure that my engine runs smoothly and holds together, so that they do not have to field my daily progress requests while the car is at their shop. This is a tremendous motivator.
Craig
Craig
Im new to the forum, but I've been there & done that!! I had a 930 which
I built from scratch, 3.6, rods, motec, full bearing turbos, port, polished
O ring heads etc...., more or less your set up but without the head gasket
issue. after the car was done (2years) there were still plenty of issues
to be dealt with. Anyway when you push these cars to the limits something
is going to break sooner or later! When I sold the car it was bitter sweet
& felt a big load off my shoulders.
I just purchased an X50 & Im putting in a stage 4 kit and thats it!!!
There will be always be somebody out there, willing to blow up there
car to be quicker then you! I built my car to be quick & to able to
handle 30 lb of boost reliable, but kept it down to 16 lb just so nothing breaks.
I was running 600 hp to the wheels with 16 lb boost, more than that
it was just down right scarry (2700 lb). Anyway it gets to the point where
you just cant put it down anyway.
Good luck on your venture!!
#49
Craig,
Sorry to hear about the issues. I am glad you have the resources and courage to continue on the path. I know you will get it sorted out. I am impressed with the members on here who are willing to share information and experience in the spirit of helping each other. I think you are definately plowing new dirt and we will all learn form your and others endeavors. Thanks for sharing and good luck. Ps what would you guess your car was capable of running the 1/4 in even soft launching it? Sounds like 10 flat or maybe high 9 to me. Anyway keep the tip owners proud my brutha! Later.
#50
The Porsche head studs 175,000 psi test. EVO head studs 175,000 psi test. The EVO head gasket is superior to the Porsche head gasket abeit you will drop approx. 2/10's compression. The grooves and copper ring method Markski is using is borrowed from the 993 motor and work very well. There is a stronger head stud currently available. I have used all three.
#51
Craig,
What you are saying about the air is partially correct. Our tests have shown that once the ambient air temperature is below 65 degrees F, the hp gains are almost none detectable. In addition, as the ambient temps drop the hp gains are not proportional for every ten degrees.
#52
Craig
Craig
#53
EVOMS' multi-layer head gasket is more than sufficient for all but the most extreme applications. This new copper head gasket is even better. Moreover, it is thinner, so I will not lose any compression (I may actually pick up a tad of compression).
Craig
#55
... This new copper head gasket is even better. Moreover, it is thinner, so I will not lose any compression (I may actually pick up a tad of compression).
Craig
Craig
#56
Sorry about your misfortune craig...
Ah well, at least now you found the weakest link! Yet another excuse to get some MORE power!! (Muhwahahahaha)
I'm sure you'll have everything sorted pretty soon. Also, real happy to hear that your trans has exceeded your expectations. If there's anything we can assist you with re: your present engine problem - let me know!
You'll be back to terrorizing the roads pretty soon I'm sure
#57
Actually, I was not referring to you. Other tuners have encountered the same problem.
Craig
Craig
#58
I am a little Lost you guys... why is it that the 9ff 910hp kit uses Titanium rods...i thought titanium was lighter but not as stronger... Also i am pressuming that its 910 with over 110 octane... Secondly has anyone thought of just using ITB's with the Porsche...that way it increases pressure into each cylinder so you dont have to run as much boost...
#59
I know that Stephen said that Titanium rods are used in race cars for one or two races... thats it.. not in street cars...
ITBs have been used b4 by someone.. I forgot who though...
2001 996TT 3.6L and stock ECU
#60
did the ITB's work out to be better or not so much with these cars.. As if thats the case i might run Dual MAF's that way i dont have to upgrade them i figure and can use stock ones i figure..
