Question on AFR/boost gauge setup etc
#46
Here is what I ended up with, except the Brockway DIN face plate is going to be carbon coated like the greddy Profec B surround when completed.
#49
#52
Deputy - I like it a lot, but no it can not datalog. There is another model that does a 2 minute datalog that remains in memory until you erase it and is re-recordable with on screen playback. It is about the size of a navagation unit and samples at a rate of 10 times per second. Here is a picture and a link http://www.brockwayengineering.com/r2000.html.
It's called the R2000
#53
Originally Posted by porschenaround
i am looking to add a boost gauge too, g-luck post pics on your projects !!
Craig
#55
I am in the process of adding a few gauges to my Boxster.
I decided to go with VDO gauges, my plans where to install a Brockway 920. I heard that Brockway is going to introduce and updated single DIN model. So I will wait for that one to come to the market and install it below my gauges where the radio is at.
A new radio that matches the interior better will be installed in the cubby hole on top of the AC controls.
I still need to add the trim piece to the ac controls and once the the brockway is installed I will trim the boost and oil gauges.
After playing with the plate it currently does not have the gap it had in this picture. I will update this when I modify it a little more.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
turbotuner20v
09-11-2015 12:02 PM
