Did Dyno Today(very Dissapointed)
Old 07-26-2006 | 03:16 PM
Billystang's Avatar
Billystang is infamous around these parts
I Went for Dyno today
my car has:
upsolute chip,bailey's diverter valves,psi exchaust,and original air box filter w/bmc high flow filter
check my results
you guys think are right?
The guy from the dyno said was flywheel HP 466.7
AWD HP:344.3 (4TH GEAR)
DYNO DYNAMICS DYNAMOMETER AWD
Old 07-26-2006 | 03:24 PM
Evan333's Avatar
Evan333 is infamous around these parts
Woah, thats a huge drivetrain loss 35%!!!! I have NEVER heard of that!! AWD loss is more like 22%-26% MAX if I remember correctly which would put you somewhere from 419HP to 433HP which for the mods you have, no does not seem right as that is STOCK power! Even if it were 466 that still isn't right for the mods you have... I have the same things (except from FVD of course) and have 530 or so flywheel HP (using only 13% drivetrain loss on a 2wd dyno).
Somthing is not right...
Evan
Old 07-26-2006 | 03:26 PM
That particular dyno always reads low... but the 466 fwhp is a bit generous...
Many P car tuners a 17.5 % drive train loss. Im sure some guys can give u a better explanation...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 07-26-2006 | 03:58 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
Evan
All Dyno Dimamics I have ever dynoed on have ben 35% driveloss for AWHP and 25% for RWHP
Old 07-26-2006 | 04:13 PM
Evan333's Avatar
Ahh my bad I was not familiar with that dyno! Either way 466BHP is VERY low for the mods he has listed!
Regards,
Evan
Old 07-26-2006 | 04:22 PM
wross996TT's Avatar
Sounds strange...I dynoed 398 with stock ECU...Europipe exhaust and V-flow intake.
Old 07-26-2006 | 04:27 PM
ECB's Avatar
ECB
ECB is infamous around these parts
Dynodynamics does read lowwww..
my car has:
check my results
My baseline with that dyno was 312 I believe.
I was pretty dissapointed as well..When I added the Gen II Variotune and a BMC, we got 351!!
Still looks like a low number I agree. I would have thought that hat you have would have gotten you more HP...ah well.
Although drag racing a porsche makes me feel kinda wierd - its actually a very objective test - short of removing your engine and tossing it on a chassis dyno...
Certainly with The exhaust, 9ff ECU and the BMC I was at 375 AWHP...right around 500HP crank - just enough to make my clutch start going...oh well. luckily for me, I happened to have a 620HP 9ff powerkit (which included a clutch) in our warehouse!
Old 07-26-2006 | 04:33 PM
Regards,
Evan
I agree. Something is OFF. Its way low!
Old 07-26-2006 | 04:57 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
I've dyno mine last year with DYNO DYNAMICS. The mod were GIAC stage 2, V-flow, RUF exhaust and got 376AWHP. But later found out they don't have any fan direct point to both inter cooler which lower the number. DYNO DYNAMICS always have the lowest number compare to other dynos.
Old 07-26-2006 | 05:00 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
How much BAR are you normally pulling on the road
circa 1.1-1.3 ?
Old 07-26-2006 | 06:59 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Billy,
Did you ask them to look at the car to determine why it was so low?
They have a STOCK 996tt dyno run on their website that shows 362 wheel HP
http://www.ktrperformance.com/dyno_t....php?id_num=47
and an upsolute/FVD exhaust that says 391 wheel HP
http://www.ktrperformance.com/dyno_t....php?id_num=48
and an EVO stage 4 that says 430 wheel HP
http://www.ktrperformance.com/dyno_t....php?id_num=46
Old 07-26-2006 | 07:01 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
I thought an ECU flash and exhaust upgrade were good for at least 80HP. You should be pushing at least 510HP at the flywheel with those mods. Get it checked out. Are you sustaining boost? Boost leaks are very common and seem to be more obvious when power is upgraded. I had "missing" HP after my upgrades, but was fixed nicely with new boost hoses and a few other goodies!
Old 07-26-2006 | 08:05 PM
JETJOX's Avatar
JETJOX is infamous around these parts
If you put that car on a dynojet, you would see right around 400 to the wheels. I can say the dynodynamics is extremely close with its flywheel hp estimates. I have tested many many factory cars with it just to verify it. If that combination should make more power then look elsewhere for problems as the others mentioned.
Old 07-26-2006 | 08:57 PM
Billystang's Avatar
when i had the evo filter i went up to 1.3 couple times.usually 1.1
Old 07-26-2006 | 09:07 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
with a very similar set up a while back, I dynoed 437 AWHP and 450AWTQ on an AWD mustang dyno.
Quick Reply: Did Dyno Today(very Dissapointed)
