Best Lightweight battery options?
I'm looking into lightweight battery options for my turbo... I have been looking at odyssey drycell batteries that I have used in the past... I was just wondering if there is any other better options....
Is 925 cranking amps enuff???
I have tried searching came up with nada
See if Braille has anything that will fit. http://www.brailleauto.com/
edit: Actually, they do. An 11.5 lb monster. clicky
i have the braille 11.5lb in my gti and i am not to satisfided with it anymore.
the ups...
-small, can fit almost anywhere
-light
-dry cell, can let drain then recharge years later
the downs...
-if your car doesn't start right away and you keep cranking, the battery is pretty much dead and needs to be charged
-if your engine is in the back and your battery is up front, a lot of power is lost with all the wires. if your engine is up front and you want a rear battery, a lot of power is lost with all the wires.
i say get the yellow top battery by Optima. i will be changing to one of those shortly.
the ups...
-light
the downs...
