Any special hints on DIY Diverter Valve replacement?
I've read through Stephen's (Imagine Auto) DIY instructions for replacing the diverter valves (thank you Stephen), and am trying to build up the courage (or stupidity, as I am not mechanically inclined) to replace mine myself.
Does anyone have hints of what NOT to do, so that I can avoid some disaster that will obviate the cost savings of doing it myself? Thanks.
Alpha-
It really is not the hard to do. I am not the best with tools, but I have changed a few sets just to be familiar with the process. I would have our technician looking over my shoulder and double check my work. Never had a problem. Smaller hands would have been the only thing that would have made the job easier.
Have a look at out install sheet is well. We install the Bailey Motorsport Diverter Valves.
http://www.awe-tuning.com/media/pdf/...twin_turbo.pdf
Hope this helps.
Thank you
Thanks to all for the hints. I can probably borrow all the tools I need, except for the all important hose clamp. Hopefuly I can get by without it.
If these guys are your friends the diverter valves should take no more then 1 hour to 1 1/2 hours. If they take longer they have obviosuly never done t before. Pretty straight forward. I would do the EVOMS F-hose at the same time.
thanks
-Sm
thanks
-Sm
Wow, I just saw that cable operated clamp tool! You should definitely borrow, buy, or steal one of those!
I was ready to "take out" the factory assembly tech who installed the clamps facing the front of the motor -- so I could not get my "bear paw" hands and a normal plier on the flange. That tool would have cured my problems. It is not really a tough job, but space is limited.
Good luck, Roger
Good luck, Roger
ECS Tuning - VW
08-19-2015 08:58 AM
