6speedonline's official 60-130, 1/4 Mile, and Standing Mile list
#4216
Chris Tapp? I remember you from vortex.
Nice time man. The power band of the A28s is awesome, glad you have rods to be able to fully take advantage of it. What RPM do you have your rev limiter set at? I noticed you ride out 4th and trap 137. I ride out 4th and trap 135-136 tops.
The limiter is at 7300 from what I can remember, I think I have logs of the run and I can check.
I am running 315 30 18 on the rear.
The sound is the tial blow off valves, I forgot to mention I have upgraded those and the piping from the intercoolers to the tb as well.
Stock plenum and throttle though.
I have had the turbo's on for 2 years , I year with stock rods, and when I took the rods out they were perfect, but people having rods bend made me decide to upgrade them.
#4217
The limiter is at 7300 form what I can remember, I think I have logs of the run and I can check.
I see you are in Ottawa, did you have a local shop do your engine build?
#4218
#4219
thanks drew !
i am going to try my 315/30/18s and see how they do in 4th. eurodyne tune im assuming?
no issues with 7.3k rev limit?
sounds good. i will try my 18s and see how they do.
#TeamAIM
#TeamAIM
#4220
No problems with the rev limit but I dont spend much time up there anyway, not neccesary with the A28's, they come in so early.
Are you still running the stock intake piping on your car?
When are you seeing full boost with the 3076's?
#4221
My boost is limited in the low-midrange, to protect the rods. full 1.5bar is at 4.5k i believe. I am using upgraded 2.5" turbo inlet piping and pull through MAF setup.
#TeamAIM
#TeamAIM
#4222
Mark Congrads Man!!! Jody had told me about your times, very impressive Traps for sure. These cars top end Game is definitely at another level
I made a pass at e-town last friday and went 11.9 @ 121
Not sure if she had more in her but definitely didnt want to over do it. IATs started low 100f with ambient temps @ 48f So I'd say she did ok.
#4223
thanks Luis !! i'll get down into more solid tens. these were just street tire shakedown passes for the heck of it. i think 11.9 is a decent time for your car, did you get the one small issue figured out that we talked about?
#TeamAIM
#TeamAIM
#4224
Member madsex343 ran a 10.18 on a 2.1% decline in his E92 M3 with Supersprint exhaust, K&N drop-in filter, and ESS tune. His 100-200 kp/h time was 8.66.
#4225
Member ysfg35 went 100-150 in 5.77 in his 997TT on 93 & meth.
Member gtovan hit 203.6 at the TX Mile in his 997 GT2 and 208.1 in his TT Z06.
#4226
thanks alot .. this was 1.55bar
new mafless tune from scott softronic , will fill tank with 109octane and boost more
#4227
Hi, divexxtreme can you put this time on the list ? Just for a comparision
Gould GR55 hillclimb single seater race car, est 650hp @450kg weight, V8 natural engine, rwd,slicks
96-209 kmh (60-130mph) in 2.5 seconds.
thank you.
thank you.
#4228
Many thanks Scott!
Much much better result than what I had in mind and I am pretty sure she still has something left in her at this stage as well...
Stay tuned... (the stock rpm limiter and the gearing of the dct does tend to take away a little of a possible better time though since at least 3 shifts are necessary here as well. .)
#4229
#4230
After 5+ years of maintaining this thread, I've decided to step away for a while. In the meantime, I'm turning over the reins to MBailey (Mike), who I'm certain will maintain the continued integrity and accuracy of the list(s). His new thread is here: https://www.6speedonline.com/forums/...le-thread.html
