gt700 unleashed
#47
Originally Posted by jags911tt
Joe what type of ypipe is that? Any benefits off using it?
It's one that Todd and the crew at EVOMS have developed that flows much more air than the factory piece.
#48
Originally Posted by RennTechV12
That's just a painted factory Y-pipe. I'm getting this one in the next few days though:
What does this new piece cost?
#49
Jags do you have the GT640 or 700, I thought you had the GT640? You really cannot use something like this, which then mates to a larger throttle body, on a GT640. You're maxing out the stock injectors as is so adding more flow/air and trying to eke out power wouldn't be safe Do the 700 first, then this stuff.
#51
Alex gtr700 all the way bro. Its been in the car for 4 months now. Maybe a gtr800 is in the mix too
#52
Originally Posted by sharkster
Ah yeah! Well bring her down then lol. We'll build that sucker up. Doing another motor build this month (top and bottom end) In terms of the engine do the cams as well. Really helps with the mid-range to counter the lag of the larger turbos
#53
What about that ypipe though
You won't be worrying about no Y-pipe at 800, that much I can confirm
#54
Oh for sure do it unless you already have the "modified" y-pipe and throttle body?
#55
So you would only suggest that y-pipe if I stay with the gtr700? What are the pros of the y-pipe with the gtr700 kit?
#57
Originally Posted by xico
put in the Evo intercoolers and change your transmission gears and you will really be surprised. I prommise!!!
1st gear is over far too quick w/ the GT700 and a LWFW. i have to shift around 6k rpm or i will hit the rev limiter.
what have others done in this dept? (not that i really need to spend anymore money...)
- chuck
#60
Originally Posted by Hamann7
RennTechV12,
Is your GT2 really confirmed as the world's fastest?
Just curious...
Just curious...
Are there any out there that are confirmed faster? I don't know
