hELp!!My Turbo is SMOKIN!!!!
Originally Posted by isaacly
you should invest in a turbo timer.. dont have a 911 turbo, but a 300zx tt. turbo timers are a must on turbo cars, even if you dont boost that much.
If you are getting smoking out your 996T's exhaust, it's likely going to be one of these items:
* engine oil level too high -- check when the engine is fully warmed up
* turbochargers worn -- remove rubber/plastic fresh air hose into the turbo compressor, check the compressor shaft for play (spec <0.8mm play)
If there is oil in the intake pipes, it's not the turbos -- probably oil being drawn into the fresh air path from the oil tank breather (tank too full)
* worn valve stem seals and/or guides -- no easy way to check these
04-28-2022 12:38 AM
johnny.dangerous
08-21-2015 10:48 AM
PelicanParts.com
08-20-2015 02:57 PM
