Gauges
Old 01-19-2004 | 06:30 PM
cjv's Avatar
cjv
Moderator
sharkster,
What wiring?
  #47
Old 01-19-2004 | 06:34 PM
luting_chen's Avatar
luting_chen is infamous around these parts
sharkster:
haven't weighted my car at all...^_^
but the only weight adding stuff on my car will be the rear subwoofer box... that's all... the rest can be removed easy in the trunk to save approximately 35lb... ^_^
I had the sun roof deleted(10-15lb??), gt3 seats installed (lets say 70lb for both??), rear seats and seat belts removed (25lb if i don't recall wrong, i measured them b4...but i might be wrong) then the spare tire is removed (25lb??? dunno). Also the rear wing is made entirely of carbon fibre.
I'll say total around 140lb removed... by the rear sub weight around 30 lb+...
I'm guessing that my car is around 100-120lb less than stock.
  #48
Old 01-19-2004 | 06:37 PM
chad: wow...that's one clean looking car... they got the wiring done nicely ^___^
chad: do you mind i ask you what gauges do you have on the car? thanx... b/c I don't really know if i need all the thing i listed or not...
  #49
Old 01-19-2004 | 06:49 PM
cjv's Avatar
cjv
Moderator
luting_chen,
Boost before throttle body
Boost after throttle body
Tire pressure and temperature
Temperature before/after and delta of intercoolers
Fuel pressure
Nitrous pressure
Head Temperature's
Oil Temperature
Water Temperature
Oil Pressure
Exhaust Port temperature's
Air Fuel Ratio
Transmission temperature
Front Differencial temperature
Now, what was forgotten?
  #50
Old 01-19-2004 | 06:57 PM
Thanx chad...
what brand of sensors do you use? the dakota ones? or????
  #51
Old 01-19-2004 | 07:01 PM
cjv's Avatar
cjv
Moderator
I'm guessing about 70% of my gauges are from Dakota Digital. I used their sensors when I used their gauges.
  #52
Old 01-19-2004 | 07:11 PM
cool cool... so it's pretty accurate then... ^^
b/c some people told me defi is more accurate and more functional...
but i like the dakota gauge...
i guess i might as well follow ur path... ^_^ hehehe...
and dakota gauges are cheaper too... around 79 each... defi bf runs 200 a piece...
  #53
Old 01-19-2004 | 07:20 PM
02barebones996:
sorry one last question ^___^
for A/F and EGT...
Are you saying to have 2 A/F and 2 EGT???? like the car Ken posted?
Or can I just have 1 EGT and 1 A/F...b/c I think they way is more easier for me to do...
My head is now all messed up with gauge pictures...hahahaha
I've been trying to think of a way to fit all these gauges into my console...
  #54
Old 01-19-2004 | 07:34 PM
cjv's Avatar
cjv
Moderator
luting_chen,
One exhaust gauge and six sensors. You can check only one tube at a time. The same with the intercoolers. You can switch to before, after or delta. The gauge reads the sensor you select.
The afr is one gauge also, it will read whichever bank you choose. My exhaust unit is from Summit Racing, it costs about 2K. The intercooler unit is from Andial. I can't remember the cost. The afr is Dakota Digital and modified by S Car Go.
  #55
Old 01-19-2004 | 07:51 PM
Zippy's Avatar
That's mighty impressive chad!
With the tire temp and pressure gauge, is there a temp. measurement for inner / mid / outer area of the footprint?
  #56
Old 01-19-2004 | 07:53 PM
wowowow.... chad... ur gauges are impressive... u got everything you need for that car....hahahaha
that sounds like 20+ gauges in ur car...
  #57
Old 01-19-2004 | 09:11 PM
Decided now...^_^
- boost
- water temp
- oil temp
- oil pressure
- egt X2...
and don't think A/F gauge is any use for me... so decided to abandon it...
but i have one more question...
regarding to the egt sensor...
is it better to install it at the exhaust manifold before the turbo(to measure TIT), or after the turbo in the exhaust as close to turbo as possible(to measure TOT)????
if measuring the TIT, it's more accurate, but it runs higher risk of damaging the turbo isn't it? (if the thermocouple breaking loose and thus damage the turbo)
but however if it's located after the turbo measuring the TOT, the temperature won't be as accurate... (up to 400 degree F in difference under load)...
Where to locate?????????????? thanx guys...
  #58
Old 01-19-2004 | 10:57 PM
sharkster's Avatar
Heck that must be like 40 pounds of wiring hehe
  #59
Old 01-20-2004 | 12:16 AM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
u only need one 1 a/f and 1 egt, and trust me the a/f is good to have when u are running more boost.. u need to check if your car is running lean or not...
  #60
Old 01-20-2004 | 01:08 AM
Joe:
thanx...
but Defi BF serie don't come with A/F gauge...
what's an alternate solution??? it's quite strange that they don't have it...@_@
and it'll look strange to have a d-serie A/F added with BF serie...
Mathme
Cayenne 958
03-23-2016 11:47 AM
Quick Reply: Gauges
