The Zero Clearance Experience- What A Ride!
#31
Originally Posted by KPG
I am not going to make it to a dyno until Sept. I think 600HP is a good assumption. I may try the video thing, our video cam is pretty old though. Kevin
hopefully you did a baseline dyno run.
#34
Originally Posted by grussell
Kevin,
I hear ya! UM is the sh*t. My GT2 is so f-ing fast it is insane. I share your exitement!
#36
16/26 ZC, wategates and programing.
#38
I take it to the track and nothing comes close. really, nothing.
Sorry missed your weight in the post.
#40
I'm curious on how the ZC turbos develop HP as the RPMs climb. Where is the peak HP/TQ developed? I'm actually curious on how the different turbos behave. I know ZC and Garrett ball-bearing hybrids tend to spool up quick, but is there a compromise, i.e. less power higher up on the RPM range?
#41
I take it to the track and nothing comes close. really, nothing. 3043lbs wet
#42
ZC turbos are non ball bearing... they use custom bushings.... I have a stage 5 set up...
It all comes down to what you want....
2001 996TT 3.6L and stock ECU
#44
Kevin uses his own wheels. no Its not bigger then a GT28. Ist not ball bearing. he uses his own custom bushings...
