Sportec Brake Cooling Ducts
Originally Posted by SANDOVAL
The kit comes with replacement raditator ducts (Large molded peices, they are just modified OEM peices.) but you will need to cut the rear wheel well cover where th ducts exit. I used a dremel with diamond wheel attachment. There is also some cutting of plastic behind the bumper to give you enough room in order for the hoses to fit.
you can order the parts from Scott at Rivalmotorsport.com or Tommy at Brandywine.
[quote=str8blst;3132064][quote=sunir;3132058]anyone have a pic of these sportec front brake cooling ducts? thanks
Here they are on my car before I took them off....
Oh I see....I thought they were actually scoops on the bottom that attached to the wheel liners? The previous owner of my car had a pair of air duct scoops put on...they are Porsche factory parts seems like but dunno if they were added in addition to the standard turbo liners or supposed to work with the gt2 liner up on the fronts...
Why did you take them off ? Do the wheels rub on full lock on the ducting ?
Feelgood MD
03-24-2016 09:35 AM
ECS Tuning - VW
09-02-2015 09:03 AM
