The Zero Clearance Experience:Part 2- The 1/4 mile and some GPS times
Well, I went to the drags tonight and it was decidedly a mixed bag. The car was running very sluggish and it was hot and humid. High 80's track temp and thunderstorms rolling in. The car never ran well and I never saw 1.2 bar all night and only saw 1.1 bar once.Basically a 1 bar night. The check engine light finally came on, but more on that later. I recently purchased a Racelogic Driftbox GPS timer and was planning on doing the high speed 60-130 at the track.This is the cousin to the VBOX which is used by most manufactures and auto mags. It updates speed and position from 4 satellites 10 times a second. It was dead on with the track times . I figure I would just keep my foot in it just a bit past the traps and that would be good for 130 . Well, the car was falling flat on its face up high and I could not get the times I wanted.I did get some some down low times. The car was absolutely ferocious down low. Spooled like mad. The best times are
ET 11.7719
Trap 122.61
60ft 1.7999
The Gps times are 0-60 3.7 sec
50-70 1.4 sec
I have posted the time slips and I will post the GPS files with more data once I figure out how to do it.
Now I really should be happy since my last trip to the drag was a 12 flat at 117 with a stage 1 EVO. My trap speed increased nearly 6 mph and the ET went down a quarter second. The power is there and these turbos flew but it is frustrating that these cars are so touchy. Now for the engine code. Apparently one of my cam banks is not adjusting properly. The code I pulled from the ECM is P1349 Camshaft Adjustment Bank 1 Below Limit. I checked my diagnostics manual and apparently my hydraulic cam solenoid isnt behaving. Anyone have this problem ? Where is the solenoid and how hard or expensive is it to change?
All in all I guess I am happy, those are pretty stout numbers with a lame cam bank. I will get this resolved and try again and get those darn 60-130 numbers. BTW what would I expect those numbers to be with a cooperating vehicle.? Remember- Zero Clearance: There Is No Substitute. Kevin
ET 11.7719
Trap 122.61
60ft 1.7999
50-70 1.4 sec
Originally Posted by rwm514
Thx for posting. Nice times. Keep us posted on how you like the drift box. What was the elevation?
Hey, you are right on the money.... 11.7 is about right. nothing to be ashamed of. I dont know more then a hand full of tts that run that... and if they do they are tuner cars...
congrats...
p.s. why were u boosting only 1.1 bars??? don't u have the upgraded springs?
congrats...
2001 996TT 3.6L and stock ECU
congrats...
congrats...
well that explains it... once u get the upgraded springs ur car will change totally. why didnt kevin hook up up with the springs from the get go?
BTW- they may be a little bit finicky getting them dialed in... some shut the TB down... I had that issue for a year til I got the diode installed. either way, 11.7 is really good.
I don't know much about the solenoid issue... but if u have warranty.. make sure u go to a freindly P car dealer to get it checked out.... casue once they see a ecu and turbos.. they may refuse the work.
markski
markski
Originally Posted by wross996TT
kevin, what kind of gas were you running? As Mark says those times are quite good!
Originally Posted by John D II
Kevin,
Very good 60' time.
What launch technique did you use?
Very good 60' time.
18 psi and 2800 rpm launch
Thanks Mark - I'll give that a try next time.
Is it safe to run at 18PSI? I'm sure it is, since you are suggesting it - but are there any concerns running such a low pressure?
What about shift points - red line every gear?
