Dock, as much as it pains me…
you were correct
The 2002 Turbo Service Information, Page 5-4, section "Bodyshell 911 Turbo/911 GT2" states:
"Extensive reinforcement measures in sill, roof frame and seat pan area increase the flectional and torsional strength by a further 25%".
Then it goes on to list what else changed...
I guess I'm wrong once per year and this is it
Roy
ps. I asked a buddy in service operations at Porsche to fax me the relevant pages of the Product Information and Service Information...
Roy
It's getting confusing......
Here is the text from a 2001 model year press release -
"With the special design of all load-bearing structures and the use of special, high-strength metal panels, Porsche’s engineers have made the bodyshell even stronger and more stable than ever before. Torsional and flexural stiffness, for example, are approximately 50 per cent better"
Here is the text from a 2002 model year press release -
"reinforcements on the side-sills, around the roof frame and seat floor panels serve to further enhance the active safety of the car. In all, these improvements improve flexural and torsional stability by another 25 per cent on the Carrera coupés and by 10 per cent on the cabriolet models"
So the pre-2001 Carrera's were 75% less rigid than 2002?? (50% from 2001 + 25% from 2002 improvements) - hard to believe.
Bond
Bond
Re: It's getting confusing......
Bond
Bond
Are you saying that 2001 was a 50% increase over 2000? That would make 2000 about 65% as stiff as 2001 and about 50% as stiff as 2002. You can't just subtract the percentages.
Either way, "stiffness" is a very loaded word and who knows what specific set of data they are actually talking about. Odds are that while it seems like a big change, the actual data is not all that important and the change in driving experience is fairly negligable.
Re: Re: It's getting confusing......
Originally posted by offroadr35
that math is not correct. if 2002 stiffness was increased by 25% thenn 2001 is 80% as stiff (80*1.25=100).
Bond
Bond
Here's my take. I think the Porsche press release refers to the initial work done in developing the 996. Here's another Porsche quote...
There's the "50%" they are referring to in the 2001 release.
The 2002 is 25% stiffer than previous 996's, after the 996 was initally 50% stiffer than the 993.
"But in the latest 911 and Boxster iterations, advanced computer analyses permit astounding gains in body rigidity - and with a much lower weight. For example, when the 1998 version of the 911 (what Porsche internally calls "996") replaced the "993" (model year 1993-1997), the entire body structure was made some 45 percent stiffer in torsion (resistance to twisting) and an astonishing 50 percent stiffer flexurally (resistance to bending in the middle) than its predecessor. For 2002, Porsche improved the 996 yet some more: a 25 percent increase in torsional rigidity for the Coupe, and 10 percent better in the Carriolet.
Thanks Dock - your last post put it all in prospective. offroadr35 had a good point also - what are the data points?, and how does this translate into a better car?.
It would seem that, since the 996 was designed by computer to optimize the strength vs. weight, it would have been difficult to go back into the design (in 2002) and add a few pcs of sheet metal here and there to gain another 25% - did the computer analysis miss something the first time around?
Also, is there any reason to believe that the TT was stiffer all along since this was the first year of the 996 wide body, and why have a one year only set of sheet metal dies (for 2001 wide body) only to revise for 2002 + years? - UNLESS the wide body and standard is virtually identical (are the frame rails and suspension mounting points the same for both wide and standard).
By the way, did anyone ever determine why the 2001 TT was preferred by some of the experts in the Excellance article (Dock, was this your original post?)
Bond
Bond
PSTT07
11-06-2015 12:57 AM
4080
10-05-2015 01:45 PM
troyztoyz609
09-17-2015 06:09 AM
