Those with PSS9s...
Old 01-22-2004 | 10:47 PM
sharkster's Avatar
Those with PSS9s...
Hey folks,
Not sure if you remember but I posted a thread about the problems with PSS9s, H&R or GT3 sway bars. Basically the drop links you may have gotten could either be bent and/or not working right. The placement of Bilstein's connector/mount on the strut is not great and also the angle causes some wackyness when you turn the wheel. If you want a solution to that (first check to see if your are bent) then just contact Viperbob because he's picking up a bunch of sets/fixes on Friday...
Old 01-23-2004 | 12:59 AM
msindi's Avatar
What exactly is the fix and how much?? I can't cvheck on my car right now but if it isnt too much $$$ I'll get a set either way
Old 01-23-2004 | 01:04 AM
sharkster's Avatar
I'll have more info for you tomorrow/Friday but for now you can Email Bob and he can explain it to you better than I can. Basically they are curved/crescent shaped to fit around the control arm and adjustable for any sway bar...
Price was $300 I believe but ask Bob. bob@renntt.com From what I have seen they are heavily over-engineered and much stronger/beefier than what came with the kit originally with PSS9s. In my book that's good.. No sense in having them brake when you're going around a turn...
Old 01-23-2004 | 06:47 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Sharky: Thanks Bud!
Now, is it at all clear yet that if you go with H&R sways you don't need the drop links? I was never able to get definitive answers but it looks like the H&R fronts do not have the problem. Anyone?
Old 01-23-2004 | 11:59 AM
sharkster's Avatar
Well on my set of PSS9s I do need these new drop links for either the H&Rs or the GT3 sways... Drop Bob an Email and he can explain that stuff to you since he is a drop link specialist
Greyghost
07-31-2004 09:01 AM
Quick Reply: Those with PSS9s...
