Zero Clearance Experience:The Numbers Are In 0-60,0-100,60-130,30-50,ET,Trap
#46
Originally Posted by Jean
Kevin
I hope you understand that I am not disputing the data. I am just correcting your earlier statements by saying that errors due to slope or mishandling or calibration can be there and undetected to anyone, regardless of how good the device is. I am saying from experience that the only way to spot them (when they are not gross) is through the data retrieve and some calculations.
Cheers
Cheers
#47
Kevin,
Sorry for going OT here, but I would like to put a word of caution...If you are on a slope, you will indeed see better times, also if your unit is not level mounted or calibrated, it can give you foul readings.
The only way to check this is through retrieving the run logs and do some calculations.
Thanks again.
Thanks again.
#48
Kevin,
Yes the data available with a simple device can be quite overwhelming. I removed my professional datalogger with all the sensors etc..to replace it with the AX22.
Here is a graph that shows the same car in 2 different runs that I consolidated together, with 2.4 seconds difference from 60-130mph. Miscalibration and/or slope, no way to pick it up.. After analyzing the raw data, turned out there was a slope in the faster run.
#49
Originally Posted by ebaker
Jean, what are you looking for in the calculations that indicates a run is not valid?
#50
Jean , here is a graph of the 7.93 sec 60-130 run with relative height and distance. You will find a deviation over approx 1200 feet of 17 feet. I assume this is considered level by your standards? Kevin
#51
Everything seems 100% good, there is no reason at all to think that these runs are not perfect. I like this feature in your logger (the altitude option)!
Ebaker, there is a certain time consuming calculation that can be done if you have all the data available the way the AX22 provides. It basically calculates the speed based on Gs...If the Gs give you a higher or lower calculated speed than the theoretical speed, it means there is tilt, slope or miscalibration. I will be happy to look into any data.
#52
#53
Originally Posted by KPG
It wil show real time data on the screen. You have to program the parameters for 60-130. It only goes to the first decimal on the real time display, so you need to download the data to a computer to get the real hard numbers, but you will leave the track with a very good idea how you ran. If you need help with the data let me know, heck you can borrow mine if you like. I am interested to see some hard numbers from other vehicles as well. I hope more AX22 data is posted. Kevin
Martin
#54
Here is some more detailed comparison data. You can only look at the long g’s or speed on separate graphs as they are scaled differently so be careful to compare the right things. Also, I would really like to see rpm data to make sure we are matching things correctly. When I am at the track, I tend to short shift and shift fairly quickly but not real fast as I am taking it easy on my car.
Here is a comparison of the long g’s (accel) from my car on turn 9-10 at Gingerman. It is pretty flat. As you can see, I am really getting outpulled in both gears. In my car’s defense, He is coming in with his foot to the floor and I am coming out of a turn so the initial accell difference is larger than it really would be. You can see his shifts look quicker, I am not sure if it is his shifting faster or quicker recovery of his higher sprung wastegates.
For the speed comparison, again, Kevin's initial advantage is overstated as I did not begin the test with full throttle. The 4th gear pull is closer
I also have some data from turn 4 into turn 5 at Road America. The beginning is pretty flat but the later portion drops downhill. You can see I get outpulled in third but we are roughly equal in fourth (here I am going downhill ).
When you look at the speed, you see the same thing. He gains on me in third but I can only stay even when going down hill.
Kevin, when you gonna have that thing in Chicago so we can visit and compare runs directly (to take out all the other variables to a meaningful comparison)?
#55
Come on Tim, I already have the hard data- its your turn now. Go to the 1/4 mile and get a trap speed. I will have a dyno sheet Mon- put your car on the dyno as well. Get me 0-60, 30-50,50-70, 0-100, 60-130 on a GPS based data logger. Heck, I will send you mine if you want. I bared my soul for all to see- do the same Kevin
#56
Tim, I am leaving for Gingerman in a bit. I have yet to try the lap data log feature but I am sure I will be able to show the same graphs at the same point on the track. As long as it doesnt rain. Kevin
#57
C'mon man, that's what I'm doing, I'm dropping mr drawers here.
Like I say, you car sure looks faster and sure looks like it boosts much quicker. Don't get my conclusions wrong. I still want to do side by side pulls. That is my favorite test.
Hey now ... anything above a 1:32 is an excuse ... you know the target. LOL ... have fun.
#58
You know Tim, with all due respect. After looking much closer at those graphs and at these speeds, the distance on track would amount to hundreds of feet. That is quite a differential. Kevin
#59
Actually, I might like to test your box. That way we at least remove equipment differences. I think I'd be up for that.
Kevin ... what part of "I think you car is spanking mine!" are you confused by?
I can do distance measures (instead of time) as well. This might be interesting.
#60
