Who is running wheel spacers??????
Hi. Some readers may not know this: Spacers are a hack to solve a
clearance problem from incorrectly-backspaced wheels, or for a purely
cosmetic reason. The ideal (but expensive) solution is to get the same
wheels you want, but with the center that much closer to the hub.
Spacers make for another failure path. Racers avoid them if at all
possible, and if necessary, the safer ones are the ones that bolt onto
the hub, and then use separate bolts to hold the wheel. The cheaper
ones that just use longer lug nuts allow for some relative motion of the
spacer and hub, and spacer and wheel, and put the lug nut into double
shear and flex if the spacer hole is not a press-fit for the lug nut.
If you're not really racing, it may not matter as much, but I wouldn't
run them.
Joe Weinstein
PS: I know that Porsche itself offers spacers. I will just go my own
cranky way with my opinion unless someone can tell me about
Porsche ever racing with spacers...
run them.
Joe Weinstein
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
PelicanParts.com
08-18-2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
