TechArt Wheel Help
TechArt Wheel Help
Hey, could somebody help me with these TechArt wheels, i need to know if they will fit my 4S (with factory spacers).
The part number off the wheels were:
FRONT WHEEL #SL-1814B W08
REAR #SL-1815B W08
the part numbers should be for 8.5*19 front and 11*19 rear.
does this sound right?
thanks
Jason
REAR #SL-1815B W08
thanks
Jason
Sounds the same offsets as a set of HRE 19's I have on my TT. Are you purshasing them locally? if so, do a test fit...
asd well, contact the US Distributor via email to see what fitments they recommend.
hey Jason, for what it's worth, I bought them for my car and ended up giving them back as they were ill-fitting! I had 8.5 x 19s and 11 x 19s and the back wheels stuck out of the wheel wells about an inch!! the dude tried to tell me that it was the way that they were designed!!!
any how, I ended up giving them back and went with the Kinesis. Good luck.
had trouble at first with the fit also, due to rubbing with the outer fender lips, so ended up adding a tad mor negative camber and rolling the fenders, now they fit and look like a dream....
- C4S and 996TT have the same width rear body.
- Same size factory wheels used on both (11x18 with 45mm offset)
- Techart's with the 40/25mm offsets are made for a 996 widebodies (996tt or C4S)!
-Z
-Z
Jason,
Thanks for the pic's.
Still on the fence, really looking for black centers.
-z
-z
REAR #SL-1815B W08
thanks
Jason
REAR #SL-1815B W08
thanks
Jason
Mackchacha
07-09-2019 11:03 AM
3WDistributing
31
10-27-2017 01:26 PM
