Taking the TT drag racing for the first time
Originally Posted by maxwell
After over-revving the first time and smoking the clutch, I tried a bunch of low rpm launches. My launches sucked, but I worked my way to a 12.34 at 119. I figure I could have brought it down a few ticks if I could get the damn thing off the line.
By the way, this was probably the first time I launched hard in 1st gear in about 3 years.
keep trying.. get that sachs gt3RS clutch and you will be fine
2001 996TT 3.6L and stock ECU
Yeah we had fun. Maxwell and I both smoked our clutches the first time and decided not to try hard launches after that. I ran 12.4 and 122.6 mph I sucked at getting off the line. My car is also not working right I installed the EVO waste gates right before going to the track and they are boosting way to much and causing ecu shut downs. On my 12.4 run the ecu shut down in 4th gear at like 5,500 rpm and I coasted past the finish 12.4 at 112 mph..
I'll get a clutch fix this waste gate crap and try again.
George
George
George, the TB will usually not shut down in the first three gears... not enough load... if and only if it happens it's usually in 4th and up.
those K24s are good for 1.2 bars sustained... anything after that and you need better flowing turbos...
Sorry OT here...KPG how is that clutch from Kevin M. as far as daily drivability and clamping force is concerned, did you notice any slippage in higher gears under WOT? Worried it will not hold the torque under max boost but it is my last chance before a Tilton setup.
my old sachs held 1174 Nm of clamping force.. its the gt3 rs one....
So do you need the LWFW with the GT3RS clutch, or can you just do the clutch?
BlackMarketRacing
12-08-2015 01:49 PM
