How To Adjust Engine Compartment Release?
Old 09-17-2006 | 05:50 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
For some strange reason when I engage the engine compartment release button near the driver's seat, the electronic release engages but the engine bay cover does not pop-up slightly anymore.
I need to lift the engine bay cover when somebody engages the button to open. Is there a way to adjust the cables or the latch?
TIA,
Adam
Old 09-17-2006 | 06:33 PM
I might be the actual latch.. there are two bolts holding it down.
When I swapped out my wing for a Gemballa wing I had to do some adjustments as well.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 09-17-2006 | 07:00 PM
alevine's Avatar
Thanks. Can I adjust the latch and make the cable tighter? Maybe it is loose.
Adam
Old 09-17-2006 | 07:10 PM
I dont think its the cable... u can open the rear lid... then use a screw driver to close the lock by pressing the hook connetecd to the wire inside the mechanism..... then have someone pull the button and u look to see if it opens the lock fully.. or does it get stuck half way... then u will know what the problem is... if not then its ur latch on the rear deck lid...
sorry for the poor explanation...
9.66
click to view
Old 09-18-2006 | 07:18 AM
t2_996420's Avatar
t2_996420 is infamous around these partst2_996420 is infamous around these parts
There are two round rubber stops/bumpers at the corner of the decklid that can be turned slightly to adjust the decklid (say if the lines of it when closed were slightly off with the bumper) - try twisting them a little (equal on each side) and see if that helps??? Just my 2 cents. T2
Old 09-18-2006 | 10:59 AM
alevine's Avatar
Great. Thanks guys for your help. I'll look into both of those suggestions. They both seem plausible.
Much appreciated,
Adam
Old 09-18-2006 | 04:43 PM
alevine's Avatar
I went out to the garage and adjusted the rubber stops. It now opens perfectly. Thanks again for your input.
Adam
Old 09-19-2006 | 02:12 PM
t2_996420's Avatar
Glad it was something easy and simple to fix....
04-28-2022 12:38 AM
dkim12
01-21-2021 04:00 PM
ECS Tuning - VW
08-27-2015 08:30 AM
Quick Reply: How To Adjust Engine Compartment Release?
