I want to see Pic and Info on the Badest Porsches!!!
#46
Originally Posted by cjv
Markski,
What have you done with your gearing. The stock first and second will be worthless.
2001 996TT 3.6L and stock ECU
#48
We went with:
1st..................3.167
2nd..................1.938
3rd..................1.474
4th..................1.174
5th..................0.968
6th..................0.821
At 8700 rpm's first would take you from about 60 mph and up depending on your tire size. Our rears have a 26.2 inch diameter. We also added a tranny cooler.
#49
We went with:
#50
We have never personally met, but we are beyond friendly. In Markski's case I provided cams and axle's when requested. Alexander and I have shared what I would call secret information and Todd has assisted us in cam pointer development/placement in conjuction with keeping the 996tt ecu while using GT3 type intake and exhaust cams.
Markski's motor is using the exact same technology, as a matter of fact, they took our cams and came up with an answer re: making them work with the 996tt ecu. We had been working on this one item for over six months with little success, multiple cams, pistons, valves and tappets being custom made and discarded. It is hard to describe the magtitude of this success.
Grab a seat and enjoy the show because when Markski publically announces the results, everyone will understand what I am talking about.
#51
Mark, Craig and CJV,
I really enjoy reading about this stuff and when Marksi gets his car done,
My wife and customers will probably be looking for me as I will immediately
drive to Chicago...Just to hear it!!!!!!!!!!
Great stuff on the top of our "TT Chain"
Marty
Marty
#52
Guest
Posts: n/a
Originally Posted by Craig
Joe is using EVOMS' GT800 turbos, same as I. The compressor is a Garrett GT30. The dyno video does not accurately reflect the lag, as they were not accelerating at WOT. Rather, they did not go WOT until well into the rpm range, at which point the turbos kicked in quickly. These turbos unquestionably lag more than k16s, k24s, or even the GT700 turbos which use a GT28 compressor. On the other hand, they make more power when they kick in. They tend to spool in the 3200-3400 rpm range. By comparison, the GT35 turbos have even more lag, but make even more power.
Craig
Craig
MARKSKI-
Your cold side of the 35R's looks smaller ??? What was the spec on that turbo again??
#53
Alex, we have both sets of housings.... trial and error. Todd wants to see how the cam stuff will work first.
#55
Originally Posted by z8cw
Anymore updates on the progress. Love to hear more.
#59
Oh my, excuse me...not catching up, outdoing yourself.
What was the rpm level you accomplished this? No matter what you basically doubled HP over stock without increasing boost levels. I had no idea how much is left on the table with these engines. From my RX7 experience I knew you have to increase the breathing capability of your engine by porting rather than just throwing bigger and bigger turbos on the engine.
Fabulous
Fabulous
#60
Originally Posted by TKDalumni
That's insane! What's your goal HP?
