Benifits of going RWD?
So.. what are the benifits of going RWD on the 996 TT.. and how do you do it.. ? and why? I know the GT2 is rwd, and so is the GT3.. But isnt the AWD system amazing on this car and doesnt it add for traction? I would assume the only reason to go rwd is HP..? does this totally remove the awd system?
besides the parasitic power loss of all four wheels, there's also the issue of weight savings. As for traction, if you're a really good driver, you can minimize the effects and the additional power to weight ratio eclipses the traction loss. This has been discussed at length, here's a good place to start. Also IllM3 hsa done this conversion and seems to love it as well. Next best thing to a true GT2 https://www.6speedonline.com/forums/...eel+conversion
I have mine done as well.... just awaiting on the car... I think its a good call to do it... lighter, nimbler.... etc...
2001 996TT 3.6L and stock ECU
IMO the car will have very similar traction in the dry (still hard to launch with nasty wheel hop) and will feel a little more poweful with better steering feedback.
The FWD takes 5% of the torque. So it feels like 5% more power which is significant in 400+ HP cars.
For the record my car only has the front driveshaft removed, so no weight gain, but it IS easily reversed.
Well Guys I must disagree on this one. I tried 2WD but after 4 days of testing I went back to 4WD due to to two major issues, the lack of LSD and the need to replace the rear arm bushings with harder units (just like Jean said...). The lack of LSD makes the car lose traction when coming out of slow, tight corners (hence the fact the GT2's come stock with LSD) and also invalidates the use of PSM as its not calibrated for 2WD and these small losses of traction (even when you can't notice them) will trigger the PSM. I also couldn't cope with the rear geometry giving under acceleration (I'm very sensitive to alignment) but I reckon the extra power and steering wheel felt great.
The cars won’t handle correctly on the stock suspension if you convert to RWD. You need to upgrade suspension, and along with that, I highly recommend corner balancing. My car with aftermarket JIC coil-overs and corner balancing handles perfectly. Much better than it did with AWD.
As far as traction, it comes down to what tires you are running. Street tires won’t cut it if you are making a lot of power. I ran street tires initially, but spun too much. Now I run R-compounds...just like the GT2 does. Lacking LSD has NOT been an issue for me on R-compounds….even with 600 rwhp.
One thing I should mention, even though I don’t have a LSD…when my car loses traction, BOTH tires spin. Not just one. Explain that one.
No personal experience but a powerful RWD TT without LSD...
...after a couple of laps I would think it definitely needs a LSD...
The 996 TT doesnt have a LSD?? I never knew that.. what a pity.. why? why would porsche do this? I mean even Subarus with AWD have LSD on the rear.. Thats just wrong imo.. Like the E55 AMG.. NO LSD Dont get it..
BY the way Divv. Your 2 wheels spinning without LSD can be explained with PSM. Just like the E55 Amg, both wheels burn out but no LSD.. This is explained by the system automatically braking each wheel seperatley at an extremely fast rate.. This transfers torque back and forth between both wheels. Causeing them both to spin.. Its sort of a fake electronic LSD.. Thats how the Benz's work..
Does Quaife make LSD's for the 996TT? And I wonder what about doing the opposite.. and adding a LSD with the AWD would make an Awsome handler..
Turbos don't need LSD in stock form because unlike subarus they are low, tarmac set up cars with stiffer sway bars and big rubber but most of all because the engine is sitting on the top of the rear wheels providing a HUGE traction advantage. There are several options to be fitted in a Turbo.
About making them "awsome handlers"...LSD's don't improve handling by themselves actually its the other way round because they promote understeer by having the inner wheel push the car in a straight line as well, this acentuates understeering behaviour and after adding an LSD you usually have to sort out the car again adjusting sway bars, different alignment and lower the front (or raising the rear) to get the extra load on the front axle.
Evo or Imagine Auto Chime in!!!
Would like to know what Evo did to there monster turbo when making it a RWD, and Stephen can you tell me the process your company performs when transforming a AWD to a RWD
thanks
thanks
so is it a smart move to just remove drive shaft and drie for a few days. have driven mine for a hour or so that way their is a difference..however it is so nice to forget about the NEVER TAKE YOUR FOOT OFF THE GAS THING if you come into a turn a little fast.. i just let off and the front tires grab and t'm done....what a min did i say that , what fun is that...sliding around is fun..
