Peak Boost on my gt700
Old 10-15-2006, 09:09 PM
Originally Posted by jags911tt
Mark I live in Washington and today it was in the low 60's. I have a call into my tuner and he will call evo and garrett on monday. What concerns me is that on the stock gauge i am seeing 1.2bar and 1.8bar on the defi. I have seen 1.3 and 1.4bar on the stock gauge before and that would mean over 2.0bar
once ur temps go up ur boost will change too.... take the car out in the morning when its even colder and ull see even higher levels.... be careful
as far as the stock guage... I would not worry about it.... just watch ur delfi.. since its connected to a vacuum source... it does not lie.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 10-15-2006, 09:12 PM
133's Avatar
133
133 is offline
133 is infamous around these parts
(A little OT, but Jags, your tt is SICK!!!)
Ok, go on...
Old 10-15-2006, 09:26 PM
oak's Avatar
oak
oak is offline
Tick...tick...sharky!
Old 10-15-2006, 09:38 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I taped into the y pipe for my boost reading. I will post the result tommorrow.
Jag
Old 10-15-2006, 09:40 PM
jags911tt's Avatar
Ok, go on...
Thanks - I need to take new pics with the new goodies
Jag
Old 10-15-2006, 10:28 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Tommorrow I'm going to have soemone sit with me a watch the gauge to see what bar is sustained.
this is why these gauges are worthless when it comes to tuning/diagnosing problems. they look trick as hell, but that's about it.
you need a good datalogger/gauge package. i keep recommending the zeitronix unit but you guys keep ignoring me
not only can you see real time values for the important stuff, you can see peak hold as well. but the really nice part is that you can plug a laptop in and datalog. it's great for reviewing and comparing TPS, AF, Boost, EGT's, etc... the peak hold numbers are just too deceptive as if you spike for a split second, that's the number you get.
Old 10-15-2006, 10:33 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
my gt700 does about 19psi peak on pump and bleeds down to 16-17psi by redline. on the race program, i get 24psi peak and bleeds down to 22-23psi by redline.
- chuck
Old 10-15-2006, 10:41 PM
sharkster's Avatar
you want a swatch with that Never used teh defi stuff but from what I've heard they're kinda strange in terms of calibration etc... pump should be sustained 20 or thereabouts and 100 should be 24 or there abouts. I only use Autometer and I guess it depends also on where it's hooked in to...
Old 10-15-2006, 11:40 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
shark look back in your old thread even you showed high boost levels lie what Im getting. Everything for me is perfect. Look back Im going to look for the post where you wrote the boost expected.
-Suman
Mike at Evo said im right where I should be. I too thought it was high. Jags your in good shape man dont worry.
Just got back and the car ripped tonight in this retardedly cold weather in CT.
Old 10-16-2006, 01:25 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Jag,
It is my very vague understanding that certain of EVOMS' programs essentially "trick" the ECU into thinking the boost is lower than it actually is, in order to prevent TB shut down. With these programs, the OEM boost guage will read lower than the actual boost (at full boost). The Defi guage will be accurate. My car has such a program. I do not know whether the GT700 prgram operates this way (or your prgram in particular).
Craig
Ps: Thats a lota boost for stock internals.
Old 10-16-2006, 09:53 AM
KPG's Avatar
KPG
KPG is offline
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by Divexxtreme
23.5 lbs? That's extremely high. I only run 1.3 bar (18.8 psi) max with my car (600 rwhp/600 rwtq), and that's using 100 octane.
Why is there such a huge difference in boost levels between similar power levels? High Hats stated a 585 rwhp at 1.6 bar and Scott 6oo rwhp at 1.3 bars. Given that the vehicles engines are relatively similar , why the same power but significantly different boost levels? Thanks, Kevin
Old 10-16-2006, 10:56 AM
i've often wondered that too. protomotive cars tend to make as much or more power to comparably equipped cars using less boost. must be a timing/software thing.
Old 10-16-2006, 11:06 AM
to be fair.. proto does custom work- almost every car they do is a one off....... evoms on the other hand sell kits that can be installed by a network of dealers... and the tuning is preprogrammed...
proto, on the other hand, is specific to ur individual car... so U would expect him to squeeze more juice out of the car...
also, he redoes the whole intake, ICs, etc...for better flow and efficiency... and thats where I think they have an edge.... he also has his own MAF solution... thats a plus....
nothing to take away from others... but Ill just stop since Im partial with my opinion and don't want to p%ss anyone off.
Tuners have different philosophies and approaches and there is nothing wrong with that....
9.66
click to view
Old 10-16-2006, 11:12 AM
Highhats's Avatar
Now rememeber my 585 whp was at 93 pctane. I was making 640whp at 100 octane program with a cycle. So I called my buddy who dynoed the car he said sustained boost of 21.5 lbs not 23 lbs and 24 lbs on 100 octane that might sound a little better to you guys but Im still boost 1.5bars.
-Suman
Old 10-16-2006, 11:24 AM
KPG's Avatar
KPG
KPG is offline
-Suman
Thanks for the clarification Kevin
Quick Reply: Peak Boost on my gt700
